Up to 20% off select tools
Logitech UE Boom Motherboard Replacement
Views: 12K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
106
All Time:
11,603
Comments: 14
12 comments on steps, 2 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Logitech UE Boom Motherboard Replacement, D-ring: step 1, image 1 of 1
      • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
      Ask FixBot
    2. Logitech UE Boom Motherboard Replacement: step 2, image 1 of 2 Logitech UE Boom Motherboard Replacement: step 2, image 2 of 2
      • Lift the handle on the D-ring and unscrew it.
      • Remove the D-ring.
      Ask FixBot
    1. Logitech UE Boom Motherboard Replacement, Bluetooth Adapter: step 3, image 1 of 1
      • Any repairs made from this point forward will void your device's warranty.
      • Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
      Ask FixBot
    2. Logitech UE Boom Motherboard Replacement: step 4, image 1 of 3 Logitech UE Boom Motherboard Replacement: step 4, image 2 of 3 Logitech UE Boom Motherboard Replacement: step 4, image 3 of 3
      • Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
      • Repeat for the bottom of the speaker and pry the casing open with your fingers.
      Ask FixBot
    3. Logitech UE Boom Motherboard Replacement: step 5, image 1 of 2 Logitech UE Boom Motherboard Replacement: step 5, image 2 of 2
      • Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
      • Do the same for the two black 7 mm screws.
      Ask FixBot
    4. Logitech UE Boom Motherboard Replacement: step 6, image 1 of 3 Logitech UE Boom Motherboard Replacement: step 6, image 2 of 3 Logitech UE Boom Motherboard Replacement: step 6, image 3 of 3
      • This next step involves the use of a hot soldering iron. Remember to be careful during this step since it can be easy to burn yourself.
      • Using a soldering iron, de-solder the two ends of the switch plate. Desolder the two terminals on headphone jack side first, as the middle connection is notched and should be slid out when molten.
      Ask FixBot
    5. Logitech UE Boom Motherboard Replacement: step 7, image 1 of 1
      • With the switch plate disconnected, remove it and your device should now look like this.
      Ask FixBot
    1. Logitech UE Boom Motherboard Replacement, Lithium Battery: step 8, image 1 of 1
      • With a metal spudger, pry open the tabs on the speaker sleeve along the length of the speaker.
      Ask FixBot
    2. Logitech UE Boom Motherboard Replacement: step 9, image 1 of 1
      • Use a plastic opening tool to pry the sleeve off from the bottom of the speaker.
      Ask FixBot
    3. Logitech UE Boom Motherboard Replacement: step 10, image 1 of 3 Logitech UE Boom Motherboard Replacement: step 10, image 2 of 3 Logitech UE Boom Motherboard Replacement: step 10, image 3 of 3
      • Peel off the sleeve.
      Ask FixBot
    4. Logitech UE Boom Motherboard Replacement: step 11, image 1 of 2 Logitech UE Boom Motherboard Replacement: step 11, image 2 of 2
      • Use a Phillips 1 screwdriver to unscrew the eight black 14 mm screws along the length of the casing.
      Ask FixBot
    5. Logitech UE Boom Motherboard Replacement: step 12, image 1 of 2 Logitech UE Boom Motherboard Replacement: step 12, image 2 of 2
      • With the screws removed, pry open the casing to be able to get to the components inside.
      • Try prying the case open from one of the ends if that is easier.
      Ask FixBot
    6. Logitech UE Boom Motherboard Replacement: step 13, image 1 of 2 Logitech UE Boom Motherboard Replacement: step 13, image 2 of 2
      • With a Phillips #00 screwdriver, unscrew two 5.6 mm screws from the rectangular shaped circuit board.
      Ask FixBot
    7. Logitech UE Boom Motherboard Replacement: step 14, image 1 of 1
      • With the Phillips #2 screwdriver, unscrew the 9.9 mm screw from the larger circuit board surrounding the speaker.
      Ask FixBot
    8. Logitech UE Boom Motherboard Replacement: step 15, image 1 of 1
      • Once all of the screws are gone, you should be able to remove the circuit boards and find the battery.
      Ask FixBot
    9. Logitech UE Boom Motherboard Replacement: step 16, image 1 of 2 Logitech UE Boom Motherboard Replacement: step 16, image 2 of 2
      • Remove the battery by pulling it from the terminal as marked in the picture.
      Ask FixBot
    1. Logitech UE Boom Motherboard Replacement, Motherboard: step 17, image 1 of 2 Logitech UE Boom Motherboard Replacement, Motherboard: step 17, image 2 of 2
      • Remove the speaker by pulling it from the terminal as marked in the picture.
      Ask FixBot
    2. Logitech UE Boom Motherboard Replacement: step 18, image 1 of 2 Logitech UE Boom Motherboard Replacement: step 18, image 2 of 2
      • Remove the second speaker by pulling it from the terminal as marked in the picture.
      Ask FixBot
    3. Logitech UE Boom Motherboard Replacement: step 19, image 1 of 2 Logitech UE Boom Motherboard Replacement: step 19, image 2 of 2
      • Finally, remove the motherboard completely by pulling it from the terminal as marked in the picture.
      Ask FixBot
7 other people completed this guide.
Author
with
Sean Reilly
1,808 Reputation
2 Guides authored
Cal Poly, Team 4-1, Maness Fall 2015 Member of Cal Poly, Team 4-1, Maness Fall 2015
CPSU-MANESS-F15S4G1
4 Members
72 Guides authored
2 Guide Comments
Is there anywhere I can buy the motherboard to replace my UE Boom board fried by lightning?
Mohd Razali Hamid - Reply Share
I would like to know where can I buy the UE BOOM Mother Board.
許志豪 - Reply Share
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 106
All Time: 11,603
