Up to 20% off select tools
Logitech UE Boom D-ring Replacement
Views: 9.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
13
Past 30 Days:
106
All Time:
9,076
Comments: 1
1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Very easy
Introduction
Go to step 1 ↓
The D-ring is located on the bottom side of the speaker, furthest from the volume buttons; it is in between the auxiliary and charging ports. Removing this part will also remove the port covers on the device. It is important to note that continuing to tear apart the speaker past this step will void the warranty on your Logitech UE Boom.
    1. Logitech UE Boom D-ring Replacement, D-ring: step 1, image 1 of 1
      • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
      Ask FixBot
    2. Logitech UE Boom D-ring Replacement: step 2, image 1 of 2 Logitech UE Boom D-ring Replacement: step 2, image 2 of 2
      • Lift the handle on the D-ring and unscrew it.
      • Remove the D-ring.
      Ask FixBot
6 other people completed this guide.
Author
with
Jose Cruz Arinaga
1,068 Reputation
3 Guides authored
Cal Poly, Team 4-1, Maness Fall 2015 Member of Cal Poly, Team 4-1, Maness Fall 2015
CPSU-MANESS-F15S4G1
4 Members
72 Guides authored
1 Guide Comment
What if it lost the d-ring and the cover port sleeve
Domingo - Reply Share
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 106
All Time: 9,076
