Up to 20% off select tools
Logitech UE Boom Bluetooth Adapter Replacement
Views: 13K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
138
All Time:
12,957
Comments: 9
9 comments on steps.
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Logitech UE Boom Bluetooth Adapter Replacement, D-ring: step 1, image 1 of 1
      • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
      Ask FixBot
    2. Logitech UE Boom Bluetooth Adapter Replacement: step 2, image 1 of 2 Logitech UE Boom Bluetooth Adapter Replacement: step 2, image 2 of 2
      • Lift the handle on the D-ring and unscrew it.
      • Remove the D-ring.
      Ask FixBot
    1. Logitech UE Boom Bluetooth Adapter Replacement, Bluetooth Adapter: step 3, image 1 of 1
      • Any repairs made from this point forward will void your device's warranty.
      • Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
      Ask FixBot
    2. Logitech UE Boom Bluetooth Adapter Replacement: step 4, image 1 of 3 Logitech UE Boom Bluetooth Adapter Replacement: step 4, image 2 of 3 Logitech UE Boom Bluetooth Adapter Replacement: step 4, image 3 of 3
      • Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
      • Repeat for the bottom of the speaker and pry the casing open with your fingers.
      Ask FixBot
    3. Logitech UE Boom Bluetooth Adapter Replacement: step 5, image 1 of 2 Logitech UE Boom Bluetooth Adapter Replacement: step 5, image 2 of 2
      • Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
      • Do the same for the two black 7 mm screws.
      Ask FixBot
    4. Logitech UE Boom Bluetooth Adapter Replacement: step 6, image 1 of 3 Logitech UE Boom Bluetooth Adapter Replacement: step 6, image 2 of 3 Logitech UE Boom Bluetooth Adapter Replacement: step 6, image 3 of 3
      • This next step involves the use of a hot soldering iron. Remember to be careful during this step since it can be easy to burn yourself.
      • Using a soldering iron, de-solder the two ends of the switch plate. Desolder the two terminals on headphone jack side first, as the middle connection is notched and should be slid out when molten.
      Ask FixBot
    5. Logitech UE Boom Bluetooth Adapter Replacement: step 7, image 1 of 1
      • With the switch plate disconnected, remove it and your device should now look like this.
      Ask FixBot
7 other people completed this guide.
Author
with
Jose Cruz Arinaga
1,068 Reputation
3 Guides authored
Cal Poly, Team 4-1, Maness Fall 2015 Member of Cal Poly, Team 4-1, Maness Fall 2015
CPSU-MANESS-F15S4G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 138
All Time: 12,957
