Up to 20% off select tools
Logitech Spotlight Battery Replacement
Views: 14K
View statistics:
Past 24 Hours:
7
Past 7 Days:
67
Past 30 Days:
385
All Time:
13,704
Comments: 23
12 comments on steps, 11 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
When your Logitech Spotlight is not charging, the battery might be the problem.
    1. Logitech Spotlight Battery Replacement, Disassembling the bottom case: step 1, image 1 of 1
      • Remove the lower casing.
      • There doesn't seem to be a way of removing that part of the casing without breaking it, so you may have to break the plastic parts.
      Ask FixBot
    2. Logitech Spotlight Battery Replacement: step 2, image 1 of 1
      • Unscrew the screws next to the charging port.
      Ask FixBot
    3. Logitech Spotlight Battery Replacement, Removing the top cover: step 3, image 1 of 1
      • Remove the top cover. Watch out for the glue.
      Ask FixBot
    4. Logitech Spotlight Battery Replacement, Removing the back plate: step 4, image 1 of 3 Logitech Spotlight Battery Replacement, Removing the back plate: step 4, image 2 of 3 Logitech Spotlight Battery Replacement, Removing the back plate: step 4, image 3 of 3
      • Remove the back plate.
      • Be careful not to break the plastic latch indicated in the image and watch out for glue.
      • Undo the screws near the top of the case. Then carefully slide the internal plastic case upward to remove it.
      • On the board underneath, remove 3 screws.
      • Watch out for the plastic latch.
      Ask FixBot
    5. Logitech Spotlight Battery Replacement, Removing the battery: step 5, image 1 of 2 Logitech Spotlight Battery Replacement, Removing the battery: step 5, image 2 of 2
      • Carefully remove the board to gain access to the battery.
      • Remove and replace the battery.
      • Once reassembled, the device should be working again.
      Ask FixBot
To reassemble your device, follow the steps in reverse order.
7 other people completed this guide.
Sae Hee
93 Reputation
1 Guide authored
11 Guide Comments
I dont't think this is an easy iFixit instruction. It's rather mid or hard especially since you have to break plastic parts to even access the screws. It might make sense to change the difficulty on this one :D @mariaparker
nils - Reply Share
@fixnils you are completely right, that was a mistake on my part! Thanks for noticing :)
Maria Parker - Reply Share
@mariaparker could we maybe add the specifications of the Lithium battery to the repair manual?
I could provide an image from my logitech spotlight to help with that.
Users are coming back again and again to ask the same question about the battery specification and the battery size.
nils - Reply Share
At step 1, I was able to twist and push a strong but thin screwdriver (Philips 000) through the plastic parts which would otherwise block access to the screws. By angling the screwdriver slightly the screws can be released without breaking the plastic completely, so you still have the retention of the usb dongle - although obviously this isn't essential.
If you have to heat-shrink connection of the original plug and new battery wires they may be too bulky for the board to go back properly in the carrier. I had to cut away small bits of ribs on the carrier
Thanks for the useful instructions
Stephen
Stephen - Reply Share
Hi,
please what are the dimensions of the 90mAh battery? Would Like to prchavé the battery before opening of the device. Thanks, Peter
Peter - Reply Share
Past 24 Hours: 7
Past 7 Days: 67
Past 30 Days: 385
All Time: 13,704
