Up to 20% off select tools
Logitech Signature Slim Solar+ Feet Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
102
All Time:
625
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Logitech
Logitech and iFixit are working together to help people repair their Logitech devices.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Follow this guide to replace worn-out or damaged feet (also known as skates, glides, slides, or pads) on your Logitech Signature Slim Solar+ keyboard.
    1. Logitech Signature Slim Solar+ Feet Replacement, Prepare your keyboard for disassembly: step 1, image 1 of 2 Logitech Signature Slim Solar+ Feet Replacement, Prepare your keyboard for disassembly: step 1, image 2 of 2
      • Slide the keyboard's power switch into the OFF position.
      • A red indicator should be visible beneath the switch.
      • Lay your keyboard down with the feet facing up on a clean work surface.
      • If your work surface may scratch the keyboard, place a soft towel under it.
      Ask FixBot
    2. Logitech Signature Slim Solar+ Feet Replacement: step 2, image 1 of 3 Logitech Signature Slim Solar+ Feet Replacement: step 2, image 2 of 3 Logitech Signature Slim Solar+ Feet Replacement: step 2, image 3 of 3
      • Insert the point of a spudger under an end of the foot.
      • Slide the spudger underneath the foot and lift until you can grip it with your fingers.
      • Peel the foot up and remove it.
      Ask FixBot
    3. Logitech Signature Slim Solar+ Feet Replacement, Install a replacement foot: step 3, image 1 of 3 Logitech Signature Slim Solar+ Feet Replacement, Install a replacement foot: step 3, image 2 of 3 Logitech Signature Slim Solar+ Feet Replacement, Install a replacement foot: step 3, image 3 of 3
      • Remove a replacement foot from its backing and firmly press it into place.
      Ask FixBot
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Author
with
Arthur Shi
354,379 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 102
All Time: 625
