Up to 20% off select tools
Logitech Signature Slim Solar+ Battery Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
62
Past 30 Days:
249
All Time:
1,947
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Moderate
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Logitech
Logitech and iFixit are working together to help people repair their Logitech devices.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Follow this guide to replace a worn-out or dead battery in your Logitech Signature Slim Solar+ keyboard.
It’s natural for batteries to lose capacity as they age. If your keyboard dies quickly and doesn't hold a charge, it may be time to replace the battery.
    1. Logitech Signature Slim Solar+ Battery Replacement, Prepare your keyboard for disassembly: step 1, image 1 of 2 Logitech Signature Slim Solar+ Battery Replacement, Prepare your keyboard for disassembly: step 1, image 2 of 2
      • Slide the keyboard's power switch into the OFF position.
      • A red indicator should be visible beneath the switch.
      • Lay your keyboard down with the feet facing up on a clean work surface.
      • If your work surface may scratch the keyboard, place a soft towel under it.
      Ask FixBot
    2. Logitech Signature Slim Solar+ Battery Replacement, Remove the feet: step 2, image 1 of 3 Logitech Signature Slim Solar+ Battery Replacement, Remove the feet: step 2, image 2 of 3 Logitech Signature Slim Solar+ Battery Replacement, Remove the feet: step 2, image 3 of 3
      • Insert the point of a spudger under an end of the foot.
      • Push the spudger underneath the foot and lift until you can grip it with your fingers.
      • Peel the foot up and remove it. Keep it for reassembly.
      Ask FixBot
    3. Logitech Signature Slim Solar+ Battery Replacement, Remove the remaining top feet: step 3, image 1 of 3 Logitech Signature Slim Solar+ Battery Replacement, Remove the remaining top feet: step 3, image 2 of 3 Logitech Signature Slim Solar+ Battery Replacement, Remove the remaining top feet: step 3, image 3 of 3
      • Repeat the procedure to remove two remaining feet along the top edge. Keep these for reassembly.
      Ask FixBot
    4. Logitech Signature Slim Solar+ Battery Replacement, Remove the battery cover: step 4, image 1 of 1
      • Use a Phillips screwdriver to loosen the three captive screws securing the battery cover.
      Ask FixBot
    5. Logitech Signature Slim Solar+ Battery Replacement: step 5, image 1 of 3 Logitech Signature Slim Solar+ Battery Replacement: step 5, image 2 of 3 Logitech Signature Slim Solar+ Battery Replacement: step 5, image 3 of 3
      • Lift and remove the battery cover.
      Ask FixBot
    6. Logitech Signature Slim Solar+ Battery Replacement: step 6, image 1 of 2 Logitech Signature Slim Solar+ Battery Replacement: step 6, image 2 of 2
      • Use your fingers or a spudger to lift and remove the battery by its side tabs.
      Ask FixBot
    7. Logitech Signature Slim Solar+ Battery Replacement, Install the replacement battery: step 7, image 1 of 3 Logitech Signature Slim Solar+ Battery Replacement, Install the replacement battery: step 7, image 2 of 3 Logitech Signature Slim Solar+ Battery Replacement, Install the replacement battery: step 7, image 3 of 3
      • Align the battery with its recess and push down firmly with your finger to click it in place.
      Ask FixBot
    8. Logitech Signature Slim Solar+ Battery Replacement, Reassemble the keyboard: step 8, image 1 of 2 Logitech Signature Slim Solar+ Battery Replacement, Reassemble the keyboard: step 8, image 2 of 2
      • Lay the battery cover in place and gently press it onto the keyboard to engage the clips.
      Ask FixBot
    9. Logitech Signature Slim Solar+ Battery Replacement: step 9, image 1 of 1
      • Use a Phillips screwdriver to tighten the three captive screws securing the battery cover.
      Ask FixBot
    10. Logitech Signature Slim Solar+ Battery Replacement: step 10, image 1 of 3 Logitech Signature Slim Solar+ Battery Replacement: step 10, image 2 of 3 Logitech Signature Slim Solar+ Battery Replacement: step 10, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • If you're installing new feet, remove them from their backing and firmly press them into place.
      • If you're reusing the feet, use a strip of double-sided tape to secure them in their recesses.
      Ask FixBot
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Author
with
Arthur Shi
354,379 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 62
Past 30 Days: 249
All Time: 1,947
