Introduction
Follow this guide to replace the chassis in your Logitech RS Shifter & Handbrake.
Unplug the shifter's USB cable.
Completely unmount the shifter from the clamp and remove any accessories so you're left with just the shifter.
Use a 4.0 mm hex screwdriver to remove the 31 mm‑long screws securing the shifter to the clamp.
Use a 2.5 mm hex screwdriver to remove the four 11 mm‑long screws securing the top cover.
Remove the eight screws securing the chassis:
Four 10 mm‑long 2.5 mm hex screws
Four 12 mm‑long Phillips screws
