Logitech RS H‑Shifter Midframe Replacement
    1. Logitech RS H‑Shifter Midframe Replacement, Before you begin: step 1, image 1 of 3 Logitech RS H‑Shifter Midframe Replacement, Before you begin: step 1, image 2 of 3 Logitech RS H‑Shifter Midframe Replacement, Before you begin: step 1, image 3 of 3
      • Before you begin your repair:
      • Unplug the H‑Shifter's USB cable.
      • Completely unmount the shifter from the clamp and remove any accessories so you're left with just the shifter.
      • Use a 4.0 mm hex screwdriver to remove the 31 mm‑long screws securing the shifter to the clamp.
      Ask FixBot
    1. Logitech RS H‑Shifter Midframe Replacement, Remove the shift knob: step 2, image 1 of 3 Logitech RS H‑Shifter Midframe Replacement, Remove the shift knob: step 2, image 2 of 3 Logitech RS H‑Shifter Midframe Replacement, Remove the shift knob: step 2, image 3 of 3
      • Twist the shift knob counterclockwise to unscrew and remove it.
      Ask FixBot
    1. Logitech RS H‑Shifter Midframe Replacement, Remove the top cover: step 3, image 1 of 2 Logitech RS H‑Shifter Midframe Replacement, Remove the top cover: step 3, image 2 of 2
      • Use a 2.5 mm hex screwdriver to remove the four 12 mm‑long screws securing the top cover.
      Ask FixBot
    2. Logitech RS H‑Shifter Midframe Replacement: step 4, image 1 of 2 Logitech RS H‑Shifter Midframe Replacement: step 4, image 2 of 2
      • Lift the top cover straight up to remove it.
      • The metal shift gate is sitting loosely in the cover.
      Ask FixBot
    1. Logitech RS H‑Shifter Midframe Replacement, Secure the gaiter: step 5, image 1 of 3 Logitech RS H‑Shifter Midframe Replacement, Secure the gaiter: step 5, image 2 of 3 Logitech RS H‑Shifter Midframe Replacement, Secure the gaiter: step 5, image 3 of 3
      • Completely unhook the fabric gaiter and use a rubber band to secure it to the shift lever.
      • During reassembly, hook the fabric back into its eight clips and four screw posts. You'll need to double up the fabric on the hooks.
      Ask FixBot
    2. Logitech RS H‑Shifter Midframe Replacement, Remove the chassis: step 6, image 1 of 2 Logitech RS H‑Shifter Midframe Replacement, Remove the chassis: step 6, image 2 of 2
      • Use a Phillips screwdriver to remove the four 12 mm‑long screws securing the chassis.
      Ask FixBot
    3. Logitech RS H‑Shifter Midframe Replacement: step 7, image 1 of 2 Logitech RS H‑Shifter Midframe Replacement: step 7, image 2 of 2
      • Lift the chassis straight up and remove it.
      Ask FixBot
    1. Logitech RS H‑Shifter Midframe Replacement, Remove the midframe: step 8, image 1 of 2 Logitech RS H‑Shifter Midframe Replacement, Remove the midframe: step 8, image 2 of 2
      • Use a long‑shank Phillips screwdriver to remove the six 17 mm‑long screws securing the midframe.
      • During reassembly, make sure you install the screws through the plastic midframe, not the large holes on the metal baseplate. You may need to use tweezers to place some of the screws because of magnets on the shifter assembly.
      Ask FixBot
    2. Logitech RS H‑Shifter Midframe Replacement: step 9, image 1 of 3 Logitech RS H‑Shifter Midframe Replacement: step 9, image 2 of 3 Logitech RS H‑Shifter Midframe Replacement: step 9, image 3 of 3
      • Lift the midframe straight up and remove it.
      Ask FixBot
Spencer Day
201,858 Reputation
1,244 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 34
All Time: 124
