Introduction
Follow this guide to replace the plastic chassis in your Logitech RS H‑Shifter.
Unplug the H‑Shifter's USB cable.
Completely unmount the shifter from the clamp and remove any accessories so you're left with just the shifter.
Use a 4.0 mm hex screwdriver to remove the 31 mm‑long screws securing the shifter to the clamp.
Use a 2.5 mm hex screwdriver to remove the four 12 mm‑long screws securing the top cover.
Completely unhook the fabric gaiter and use a rubber band to secure it to the shift lever.
Use a Phillips screwdriver to remove the four 12 mm‑long screws securing the chassis.
