Up to 20% off select tools
Logitech Pro X 60 Battery Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
120
All Time:
709
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace a worn-out or dead battery in your Logitech Pro X 60 wireless keyboard.
It’s natural for batteries to lose capacity as they age. If your keyboard dies quickly and doesn't hold a charge, it may be time to replace the battery.
For safety, perform this repair when your battery is below 15% charge. Any charged lithium-ion battery can be hazardous if punctured or damaged. If your battery looks puffy or swollen, take appropriate precautions.
    1. Logitech Pro X 60 Battery Replacement, Prepare your keyboard for disassembly: step 1, image 1 of 3 Logitech Pro X 60 Battery Replacement, Prepare your keyboard for disassembly: step 1, image 2 of 3 Logitech Pro X 60 Battery Replacement, Prepare your keyboard for disassembly: step 1, image 3 of 3
      • Slide the power switch on the top edge of the keyboard to the OFF position.
      • A red indicator should be visible beneath the switch.
      • Unplug all cables from your keyboard.
      • Lay your keyboard down with the feet facing up on a clean work surface.
      • If your work surface might scratch the keyboard, place a soft towel under it.
      Ask FixBot
    1. Logitech Pro X 60 Battery Replacement, Remove the sticker: step 2, image 1 of 2 Logitech Pro X 60 Battery Replacement, Remove the sticker: step 2, image 2 of 2
      • The Logitech sticker hides two battery cover screws.
      • Heat an iOpener and lay it on the Logitech sticker for one minute.
      • Alternatively, you can use a hair dryer to heat the sticker. Make sure it's on the Low setting to avoid warping the plastic.
      Ask FixBot
    2. Logitech Pro X 60 Battery Replacement: step 3, image 1 of 3 Logitech Pro X 60 Battery Replacement: step 3, image 2 of 3 Logitech Pro X 60 Battery Replacement: step 3, image 3 of 3
      • Use an opening tool, spudger, or your fingernail to peel up a corner of the sticker until you can grip it with your fingers.
      • Peel up the sticker with your fingers and remove it.
      Ask FixBot
    3. Logitech Pro X 60 Battery Replacement, Remove the battery cover screws: step 4, image 1 of 2 Logitech Pro X 60 Battery Replacement, Remove the battery cover screws: step 4, image 2 of 2
      • Use a Phillips screwdriver to remove the four 6 mm‑long screws securing the battery cover.
      Ask FixBot
    4. Logitech Pro X 60 Battery Replacement, Remove the battery cover: step 5, image 1 of 2 Logitech Pro X 60 Battery Replacement, Remove the battery cover: step 5, image 2 of 2
      Tool used on this step:
      Suction Handle
      $2.95
      Buy
      • Carefully flip your keyboard over and gently wiggle the battery cover to remove it.
      • If the battery cover is stuck in its recess, you can use a suction handle to lift it out.
      • Once you've removed the cover, flip your keyboard back over and lay it down so the feet are facing up.
      Ask FixBot
    5. Logitech Pro X 60 Battery Replacement, Disconnect the battery: step 6, image 1 of 3 Logitech Pro X 60 Battery Replacement, Disconnect the battery: step 6, image 2 of 3 Logitech Pro X 60 Battery Replacement, Disconnect the battery: step 6, image 3 of 3
      • Use a pair of angled tweezers to firmly grip the battery connector.
      • Hold the tweezers with your fingers as close to the connector as possible to get a firm hold.
      • Gently rock the connector side‑to‑side and slide it straight out of the socket.
      Ask FixBot
    6. Logitech Pro X 60 Battery Replacement, Apply isopropyl alcohol: step 7, image 1 of 3 Logitech Pro X 60 Battery Replacement, Apply isopropyl alcohol: step 7, image 2 of 3 Logitech Pro X 60 Battery Replacement, Apply isopropyl alcohol: step 7, image 3 of 3
      • Mild adhesive secures the battery in its recess.
      • Apply a few drops of high‑concentration (>90%) isopropyl alcohol along the bottom edge of the battery.
      • Slightly tilt your keyboard so the alcohol flows towards the center of the battery.
      • Keep your keyboard tilted and wait one minute for the alcohol to soften the adhesive.
      Ask FixBot
    7. Logitech Pro X 60 Battery Replacement, Remove the battery: step 8, image 1 of 3 Logitech Pro X 60 Battery Replacement, Remove the battery: step 8, image 2 of 3 Logitech Pro X 60 Battery Replacement, Remove the battery: step 8, image 3 of 3
      Tesa 61395 Tape
      $2.95
      Buy
      • Make sure you push your tool underneath the battery and not into it. Don't bend or deform the battery.
      • Slide an opening pick under the bottom edge of the battery and gently lift to separate the adhesive securing it to the keyboard.
      • Remove the battery.
      • During reassembly:
      • Remove the old adhesive from the battery recess.
      • Apply a strip of thin, double‑sided tape to the battery recess, where the old adhesive was.
      • Lay the battery into its recess so the cable is on the side with the connector.
      • Press the battery into place to secure it with the adhesive.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Author
with
Spencer Day
210,836 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 120
All Time: 709
