Up to 20% off select tools
Logitech POP Mouse Battery Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
8
Past 7 Days:
52
Past 30 Days:
301
All Time:
2,876
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 seconds - 1 minute
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
When the batteries in your Logitech POP Mouse die, it is difficult to get any work done. Here's how to swap the batteries in your mouse.
This guide is for the 910-007408 and 910-007409 models of the Logitech POP Mouse.
    1. Logitech POP Mouse Battery Replacement, Battery: step 1, image 1 of 1
      • Flip the mouse over so the bottom is facing up.
      • Slide the power switch off.
      • Make sure that the plate behind the switch is red so that you know it's off.
      Ask FixBot
    2. Logitech POP Mouse Battery Replacement: step 2, image 1 of 1
      • Flip the mouse back over so it is facing upright.
      • The top cover is attached to the bottom by three small magnets located in the palm rest. Pulling up on the top plastic by the edges should detach the top from the bottom with little force.
      Ask FixBot
    3. Logitech POP Mouse Battery Replacement: step 3, image 1 of 1
      • Press down on the part of the battery closest to the front of the mouse to pop the backend of it upwards, and then gently pull the battery out.
      Ask FixBot
    4. Logitech POP Mouse Battery Replacement: step 4, image 1 of 1
      • Insert the battery into the slot.
      • The battery compartment has a sticker to remind you which direction the battery needs to face.
      • Place the cover plate over the mouse, and the magnetic connectors should slide the cover into place.
      Ask FixBot
    5. Logitech POP Mouse Battery Replacement: step 5, image 1 of 1
      • Turn your mouse back on using the same switch as earlier. If everything was done correctly, your mouse should be good as new!
      Ask FixBot
Finish Line
Author
with
CoffeeAndE
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 52
Past 30 Days: 301
All Time: 2,876
