Up to 20% off select tools
Logitech Mouse MX1000 Disassembly
Views: 2.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
26
Past 30 Days:
131
All Time:
2,148
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes - 1 hour
Difficulty: Difficult
Community-Contributed Guide
Tools
    1. Logitech Mouse MX1000 Disassembly, Open the housing: step 1, image 1 of 2 Logitech Mouse MX1000 Disassembly, Open the housing: step 1, image 2 of 2
      • There are four screws hidden on the bottom part of the mouse. Two are below the sticker, the last two are below the bottom pads.
      Ask FixBot
    2. Logitech Mouse MX1000 Disassembly, Disconnect the cables: step 2, image 1 of 3 Logitech Mouse MX1000 Disassembly, Disconnect the cables: step 2, image 2 of 3 Logitech Mouse MX1000 Disassembly, Disconnect the cables: step 2, image 3 of 3
      • Once the scews removed, carefully open the housing. Some cables hold both pieces together
      • First remove the tricolor battery cable
      • Then carefully remove the ribbon cable
      Ask FixBot
    3. Logitech Mouse MX1000 Disassembly, Remove the battery: step 3, image 1 of 1
      • To remove the battery cover, two more screws need to be removed.
      • The battery is then held in place with a sticker within the housing.
      Ask FixBot
    4. Logitech Mouse MX1000 Disassembly, Remove the board from the housing: step 4, image 1 of 3 Logitech Mouse MX1000 Disassembly, Remove the board from the housing: step 4, image 2 of 3 Logitech Mouse MX1000 Disassembly, Remove the board from the housing: step 4, image 3 of 3
      • Remove the three screws (red circles) holding the board in place
      • Remove the wheel and the white piece of plastic holding it down
      • A clip (yellow circle) further holds it down
      • Finally you need to unsolder the charging pads (orange circles)
      Ask FixBot
    5. Logitech Mouse MX1000 Disassembly, You are done: step 5, image 1 of 1
      • Congrats, you now fully dissassembled your logitech mouse!
      Ask FixBot
Author
with
lija31415
313 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 131
All Time: 2,148
