Community-Contributed Guide
Tools
Spudger4.9
Introduction
Go to step 1 ↓This guide cover disassembly for purpose of switch replacement, but does not cover the actual switch replacement beyond advice and useful help in sourcing a replacement.
Turn the mouse over to access the bottom.
Using a scalpel, pick, or similar tool, peel off the front and rear soles (slide pads) on the bottom of the mouse. This exposes three screws.
Using a Phillips #0 driver, remove the three screws circled in red.
Carefully separate the two halves of the case. Light prying may be required. If you examine the second photo you can see one of the plastic retaining tabs on the front of the top half. A pick or similar tool prove helpful without marring the case.
Remove the three Phillips PH000 screws circled in orange; The PCB can then be removed for inspection and repair.
My experience was one switch working intermittently. In such a case, I recommend replacing both the left and right switches.
This may be helpful in finding the correct or compatible replacement i.e. online vendors such as AliExpress.
What I used as a successful replacement: RS Components Stock No. 682-1519 microswitch. Manufactured by Omron—part number: D2F-F.
3 other people completed this guide.
