Up to 20% off select tools
Logitech MX Vertical Feet Replacement
Views: 7.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
42
Past 30 Days:
227
All Time:
7,151
Comments: 4
4 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide remove and replace worn out mouse feet (also called skates or pads) on the bottom of a Logitech MX Vertical wireless mouse.
If thoroughly heated, the mouse feet can be cleanly removed, but you may need replacement feet if one rips or some of its adhesive is left behind.
    1. Logitech MX Vertical Feet Replacement, Turn off the mouse: step 1, image 1 of 1
      • Before you begin, flip the mouse's power switch down into the OFF position.
      • Unplug all cables from the mouse.
      Ask FixBot
    2. Logitech MX Vertical Feet Replacement, Lay the mouse buttons-side down: step 2, image 1 of 1
      • The mouse's unique shape prevents it from laying flat. If you need to, lay it down on a soft towel to prevent wobble.
      Ask FixBot
    3. Logitech MX Vertical Feet Replacement, Heat the feet adhesive: step 3, image 1 of 2 Logitech MX Vertical Feet Replacement, Heat the feet adhesive: step 3, image 2 of 2
      • If you're planning to reuse your existing mouse feet, the adhesive needs to be thoroughly heated for them to be cleanly removed.
      • Heat an iOpener and apply it to the feet on the mouse's underside for two minutes.
      • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
      • If you're using a hair dryer, only heat the feet a few seconds at a time or you might warp the plastic shell.
      Ask FixBot
    4. Logitech MX Vertical Feet Replacement, Remove the mouse feet: step 4, image 1 of 3 Logitech MX Vertical Feet Replacement, Remove the mouse feet: step 4, image 2 of 3 Logitech MX Vertical Feet Replacement, Remove the mouse feet: step 4, image 3 of 3
      • Insert one arm of a pair of angled tweezers underneath the end of one foot.
      • Grip the foot and begin to peel it away from the bottom of the mouse.
      • Peel slowly, making sure the foot and its adhesive are removed in one piece.
      • The foot should come away from the mouse without the need for much force. If it feels stuck, apply more heat and try again.
      Ask FixBot
    5. Logitech MX Vertical Feet Replacement: step 5, image 1 of 3 Logitech MX Vertical Feet Replacement: step 5, image 2 of 3 Logitech MX Vertical Feet Replacement: step 5, image 3 of 3
      • Use the tweezers to peel the foot away from the mouse to completely remove it.
      • If you're reusing the foot, place it adhesive-side up on a clean surface.
      Ask FixBot
    6. Logitech MX Vertical Feet Replacement: step 6, image 1 of 3 Logitech MX Vertical Feet Replacement: step 6, image 2 of 3 Logitech MX Vertical Feet Replacement: step 6, image 3 of 3
      • Repeat the process to remove the other foot.
      • To install a new foot:
      • If any of the feet got damaged during removal or separated from their adhesive pads, replace them.
      • Use a spudger to carefully scrape up and remove any remaining adhesive bits.
      • Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry.
      • Remove the feet from their backing and firmly press them into place.
      Ask FixBot
6 other people completed this guide.
Author
with
Carsten Frauenheim
175,088 Reputation
442 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
4 Guide Comments
Do you have to heat it to re-apply the feet?
Jimmy - Reply Share
Beste,
Weet je toevallig, waar ik de nieuwe voetjes van Logitech MX Vertical kan kopen?
Groeten,
peter smith
peter - Reply Share
where can you get new slide tape or feet?
Jerry - Reply Share
Aliexpress has it (look for MX Vertical glide)
or in this tutorial has a link to corepad.de website that sell them:
Logitech MX Vertical Left and Right Mouse Button Microswitch Replacement
it should have been added to this tutorial as well.
tridy - Reply Share
Past 24 Hours: 3
Past 7 Days: 42
Past 30 Days: 227
All Time: 7,151
