Logitech MX Mechanical Mini Battery Replacement
    1. Logitech MX Mechanical Mini Battery Replacement, Prepare the keyboard for disassembly: step 1, image 1 of 3 Logitech MX Mechanical Mini Battery Replacement, Prepare the keyboard for disassembly: step 1, image 2 of 3 Logitech MX Mechanical Mini Battery Replacement, Prepare the keyboard for disassembly: step 1, image 3 of 3
      • Unplug any cables from the keyboard.
      • Slide the power switch on the top edge of the keyboard to the OFF (right) position.
      • You should see a red indicator under the switch.
      • Lay the keyboard upside down on a clean work surface.
      • Place a soft towel under the keyboard if your work surface might scratch the keys.
      Ask FixBot
    2. Logitech MX Mechanical Mini Battery Replacement, Remove the sticker: step 2, image 1 of 2 Logitech MX Mechanical Mini Battery Replacement, Remove the sticker: step 2, image 2 of 2
      • The sticker on the bottom of the keyboard hides the two battery cover screws.
      • Heat an iOpener and lay it on the top edge of the sticker for one minute.
      • Alternatively, use a hair dryer on its low-heat setting to heat the sticker.
      Ask FixBot
    3. Logitech MX Mechanical Mini Battery Replacement: step 3, image 1 of 3 Logitech MX Mechanical Mini Battery Replacement: step 3, image 2 of 3 Logitech MX Mechanical Mini Battery Replacement: step 3, image 3 of 3
      • The keyboard will work normally without the sticker. Follows these steps to remove it intact if you want to re-apply the sticker at the end of the procedure.
      • Use a spudger or your fingernail to peel up a corner of the sticker until you can grip it with your fingers.
      • Peel up the sticker and remove it.
      • If the sticker doesn't peel up easily, use an iOpener or hair dryer to heat the sticker again.
      Ask FixBot
    4. Logitech MX Mechanical Mini Battery Replacement, Remove the battery cover: step 4, image 1 of 2 Logitech MX Mechanical Mini Battery Replacement, Remove the battery cover: step 4, image 2 of 2
      • Use a Phillips screwdriver to remove the two 5.5 mm‑long screws securing the battery cover.
      Ask FixBot
    5. Logitech MX Mechanical Mini Battery Replacement: step 5, image 1 of 3 Logitech MX Mechanical Mini Battery Replacement: step 5, image 2 of 3 Logitech MX Mechanical Mini Battery Replacement: step 5, image 3 of 3
      • Insert the tip of a spudger into one of the screw holes in the battery cover.
      • Use the spudger to lift and remove the battery cover.
      Ask FixBot
    6. Logitech MX Mechanical Mini Battery Replacement, Remove the battery: step 6, image 1 of 2 Logitech MX Mechanical Mini Battery Replacement, Remove the battery: step 6, image 2 of 2
      • Be very careful to avoid hitting the battery with the tweezers. Even a discharged lithium-ion battery can pose a safety risk if punctured or damaged.
      • Insert the tips of a pair of angled tweezers into the small recesses on the top of the battery connector, between the battery connector and its socket.
      • Gently push the battery connector out of its socket. Use a side-to-side rocking motion if it feels stuck.
      • Use gentle, steady pressure to prevent the tweezers from slipping.
      Ask FixBot
    7. Logitech MX Mechanical Mini Battery Replacement: step 7, image 1 of 3 Logitech MX Mechanical Mini Battery Replacement: step 7, image 2 of 3 Logitech MX Mechanical Mini Battery Replacement: step 7, image 3 of 3
      • If the battery starts to bend, stop immediately and apply isopropyl alcohol as described at the end of this step.
      • Insert the flat end of a spudger under the right edge of the battery, near the top.
      • Gently pry the battery up until the adhesive releases and remove the battery.
      • If the battery is stuck:
      • Prop up the right edge of the keyboard and apply a few drops of high-concentration (>90%) isopropyl alcohol under the right edge of the battery.
      • Wait a few minutes and try to pry up the battery again.
      • If the battery is still stuck, apply more alcohol around the edges of the battery and prop up different edges of the keyboard so the alcohol can dissolve the adhesive all around the battery.
      Ask FixBot
    8. Logitech MX Mechanical Mini Battery Replacement, Clean the adhesive residue: step 8, image 1 of 2 Logitech MX Mechanical Mini Battery Replacement, Clean the adhesive residue: step 8, image 2 of 2
      • Apply a few drops of high-concentration (>90%) isopropyl alcohol to a microfiber or lint-free cloth.
      • Use the cloth to clean any adhesive residue out of the battery well.
      Ask FixBot
    9. Logitech MX Mechanical Mini Battery Replacement, Install the new battery: step 9, image 1 of 3 Logitech MX Mechanical Mini Battery Replacement, Install the new battery: step 9, image 2 of 3 Logitech MX Mechanical Mini Battery Replacement, Install the new battery: step 9, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • Apply a wide strip of double-sided tape, like Tesa tape, near the top edge of the battery well.
      • Leave the liner on the back of the tape and use your finger to press the tape to the keyboard.
      • Repeat this process to apply another strip of double-sided tape near the bottom edge of the battery well.
      Ask FixBot
    10. Logitech MX Mechanical Mini Battery Replacement: step 10, image 1 of 3 Logitech MX Mechanical Mini Battery Replacement: step 10, image 2 of 3 Logitech MX Mechanical Mini Battery Replacement: step 10, image 3 of 3
      • Use your fingers to peel up and remove the liners on the double-sided tape.
      Ask FixBot
    11. Logitech MX Mechanical Mini Battery Replacement: step 11, image 1 of 2 Logitech MX Mechanical Mini Battery Replacement: step 11, image 2 of 2
      • Orient the battery so the label faces up and the battery connector points towards its socket.
      • Lower the battery into the battery well.
      • Use your fingers to firmly press the battery into the well to secure the adhesive.
      Ask FixBot
    12. Logitech MX Mechanical Mini Battery Replacement, Connect the battery: step 12, image 1 of 2 Logitech MX Mechanical Mini Battery Replacement, Connect the battery: step 12, image 2 of 2
      • Place the tips of a pair of angled tweezers on either side of the wires on the battery connector.
      • Use gentle, steady pressure to pull the battery connector into its socket.
      • Try turning the keyboard on. If it doesn't turn on, make sure the battery connector is fully seated in its socket.
      Ask FixBot
    13. Logitech MX Mechanical Mini Battery Replacement, Install the battery cover: step 13, image 1 of 2 Logitech MX Mechanical Mini Battery Replacement, Install the battery cover: step 13, image 2 of 2
      • Insert the tabs on the top edge of the battery cover into their cutouts on the top edge of the battery well.
      • Lay the cover down into its recess. It should lay flush with the keyboard.
      Ask FixBot
    14. Logitech MX Mechanical Mini Battery Replacement: step 14, image 1 of 2 Logitech MX Mechanical Mini Battery Replacement: step 14, image 2 of 2
      • Use a Phillips screwdriver to install the two 5.5 mm‑long screws to secure the battery cover.
      Ask FixBot
    15. Logitech MX Mechanical Mini Battery Replacement, Re-apply the sticker: step 15, image 1 of 2 Logitech MX Mechanical Mini Battery Replacement, Re-apply the sticker: step 15, image 2 of 2
      • This step is optional. The keyboard will work normally without the sticker.
      • Carefully align the sticker with its recess in the keyboard.
      • To match the original orientation, "MX Mechanical Mini" should be near the center of the keyboard.
      • Use your fingers to firmly press the sticker onto the keyboard.
      Ask FixBot
Congratulations on completing your repair!
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Spencer Pennington
27,115 Reputation
126 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 66
All Time: 712
