Tools
Introduction
Go to step 1 ↓Follow this guide to replace worn‑out or damaged feet (also known as skates, glides, slides, or pads) on your Logitech MX Master 4.
Flip the mouse's power switch down into the OFF position and unplug any cables.
Heat an iOpener and lay it on each of the mouse feet for one minute.
Slowly slide the tip of an opening pick under one of the feet.
Slide the pick farther under the foot and lift until you can grip the foot with your fingers.
Use your fingers to peel up and remove the foot.
Thoroughly clean all the foot recesses with isopropyl alcohol and a lint‑free or microfiber cloth. Allow the surface to dry completely.
Peel your new mouse feet off their adhesive liners and press them firmly into place.
Congratulations on completing your repair!
