Logitech MX Master 3S Mouse Feet Replacement
    1. Logitech MX Master 3S Mouse Feet Replacement, Soften the mouse feet adhesive: step 1, image 1 of 3 Logitech MX Master 3S Mouse Feet Replacement, Soften the mouse feet adhesive: step 1, image 2 of 3 Logitech MX Master 3S Mouse Feet Replacement, Soften the mouse feet adhesive: step 1, image 3 of 3
      • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
      • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
      • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
      • Heat an iOpener and apply it to each of the mouse feet for about one minute each.
      • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
      • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
      • The information sticker adhesive may soften during this step, but you don't need to remove it.
      Ask FixBot
    2. Logitech MX Master 3S Mouse Feet Replacement, Separate the mouse foot adhesive: step 2, image 1 of 3 Logitech MX Master 3S Mouse Feet Replacement, Separate the mouse foot adhesive: step 2, image 2 of 3 Logitech MX Master 3S Mouse Feet Replacement, Separate the mouse foot adhesive: step 2, image 3 of 3
      • Slide an opening pick under an edge of the left mouse foot.
      • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
      • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
      • If the foot feels stuck, apply more heat before continuing.
      • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
      • Peel up and remove the left mouse foot.
      Ask FixBot
    3. Logitech MX Master 3S Mouse Feet Replacement, Remove the remaining feet: step 3, image 1 of 3 Logitech MX Master 3S Mouse Feet Replacement, Remove the remaining feet: step 3, image 2 of 3 Logitech MX Master 3S Mouse Feet Replacement, Remove the remaining feet: step 3, image 3 of 3
      • Repeat the previous two steps for the three remaining feet.
      • The front foot doesn't cover any screws—if you're only removing the mouse feet to open up the mouse, you don't need to remove this foot.
      Ask FixBot
    4. Logitech MX Master 3S Mouse Feet Replacement, Reassembly information: step 4, image 1 of 3 Logitech MX Master 3S Mouse Feet Replacement, Reassembly information: step 4, image 2 of 3 Logitech MX Master 3S Mouse Feet Replacement, Reassembly information: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • If the adhesive separated from the foot:
      • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
      • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
      • For installing new mouse feet or reusing your old ones:
      • Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free or microfiber cloth. Allow the surface to dry completely.
      • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
      Ask FixBot
7 other people completed this guide.
Alex Diaz-Kokaisl
248,576 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 131
Past 30 Days: 517
All Time: 21,300
