Logitech MX Master 2S Mouse Feet Replacement
    1. Logitech MX Master 2S Mouse Feet Replacement, Soften the mouse feet adhesive: step 1, image 1 of 1
      • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
      • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
      • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
      • Heat an iOpener and apply it to the mouse feet for about two minutes.
      • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
      • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
      Ask FixBot
    2. Logitech MX Master 2S Mouse Feet Replacement, Separate the mouse foot adhesive: step 2, image 1 of 3 Logitech MX Master 2S Mouse Feet Replacement, Separate the mouse foot adhesive: step 2, image 2 of 3 Logitech MX Master 2S Mouse Feet Replacement, Separate the mouse foot adhesive: step 2, image 3 of 3
      • Insert an opening pick between the left foot and the lower case.
      • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
      • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
      • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
      • If the pick feels stuck, apply more heat before continuing.
      Ask FixBot
    3. Logitech MX Master 2S Mouse Feet Replacement, Remove the mouse foot: step 3, image 1 of 2 Logitech MX Master 2S Mouse Feet Replacement, Remove the mouse foot: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers or your fingers to remove the mouse foot.
      Ask FixBot
    4. Logitech MX Master 2S Mouse Feet Replacement, Remove the remaining feet: step 4, image 1 of 3 Logitech MX Master 2S Mouse Feet Replacement, Remove the remaining feet: step 4, image 2 of 3 Logitech MX Master 2S Mouse Feet Replacement, Remove the remaining feet: step 4, image 3 of 3
      • Repeat the previous two steps for the three remaining feet.
      Ask FixBot
    5. Logitech MX Master 2S Mouse Feet Replacement, Reassembly information: step 5, image 1 of 3 Logitech MX Master 2S Mouse Feet Replacement, Reassembly information: step 5, image 2 of 3 Logitech MX Master 2S Mouse Feet Replacement, Reassembly information: step 5, image 3 of 3
      • For installing new mouse feet or reusing your old ones:
      • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
      • Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
      • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
      Ask FixBot
2 other people completed this guide.
Alex Diaz-Kokaisl
248,438 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
1 Guide Comment
Are those feet the same shape as the ones in the original MX Master?
Bastian Hodapp - Reply Share
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 145
All Time: 9,635
