Logitech MX Keys for Mac Battery Replacement
View statistics:
Past 24 Hours:
7
Past 7 Days:
33
Past 30 Days:
101
All Time:
621
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Follow this guide to replace a worn-out or dead battery in your Logitech MX Keys for Mac wireless keyboard.
It’s natural for batteries to lose capacity as they age. If your keyboard dies quickly and doesn't hold a charge, it may be time to replace the battery.
For safety, perform this repair when your battery is below 15% charge. Any charged lithium-ion battery can be hazardous if punctured or damaged. If your battery looks puffy or swollen, take appropriate precautions.
Parts
Tools
    1. Logitech MX Keys for Mac Battery Replacement, Prepare your keyboard for disassembly: step 1, image 1 of 3 Logitech MX Keys for Mac Battery Replacement, Prepare your keyboard for disassembly: step 1, image 2 of 3 Logitech MX Keys for Mac Battery Replacement, Prepare your keyboard for disassembly: step 1, image 3 of 3
      • Slide the keyboard's power switch into the OFF position.
      • A red indicator should be visible beneath the switch.
      • Unplug all cables from the keyboard.
      • Lay the keyboard down with the feet facing up on a clean work surface.
      • If your work surface may scratch the keyboard, place a soft towel under it.
      Ask FixBot
    2. Logitech MX Keys for Mac Battery Replacement, Heat the feet: step 2, image 1 of 2 Logitech MX Keys for Mac Battery Replacement, Heat the feet: step 2, image 2 of 2
      • Heat an iOpener and lay it on the top left foot for one minute.
      • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
      • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic.
      Ask FixBot
    3. Logitech MX Keys for Mac Battery Replacement, Remove the feet: step 3, image 1 of 3 Logitech MX Keys for Mac Battery Replacement, Remove the feet: step 3, image 2 of 3 Logitech MX Keys for Mac Battery Replacement, Remove the feet: step 3, image 3 of 3
      • The foot should come up without much force. If it feels stuck, apply more heat and try again.
      • Insert the point of a spudger under an end of the foot.
      • Push the spudger underneath the foot and lift until you can grip it with your fingers.
      • Peel the foot up and remove it.
      • Repeat the process to remove the remaining feet.
      • If you're replacing the battery, you only need to remove the feet along the top edge.
      Ask FixBot
    4. Logitech MX Keys for Mac Battery Replacement, Reassembly information: step 4, image 1 of 2 Logitech MX Keys for Mac Battery Replacement, Reassembly information: step 4, image 2 of 2
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • To install the feet during reassembly:
      • Use a pair of angled tweezers to peel up and remove all the plastic film from the foot recesses.
      • If you're installing new feet, remove them from their backing and firmly press them into place.
      • If you're reusing the feet, use a strip of double-sided tape to secure them in their recesses.
      Ask FixBot
    1. Logitech MX Keys for Mac Battery Replacement, Remove the battery cover: step 5, image 1 of 3 Logitech MX Keys for Mac Battery Replacement, Remove the battery cover: step 5, image 2 of 3 Logitech MX Keys for Mac Battery Replacement, Remove the battery cover: step 5, image 3 of 3
      • Plastic film may be covering the screws in the top edge foot recesses.
      • Use the pointed end of a spudger to poke through each film so you can access the screw underneath.
      Ask FixBot
    2. Logitech MX Keys for Mac Battery Replacement: step 6, image 1 of 2 Logitech MX Keys for Mac Battery Replacement: step 6, image 2 of 2
      • Use a Phillips screwdriver to remove the three 7.6 mm‑long screws securing the battery cover.
      Ask FixBot
    3. Logitech MX Keys for Mac Battery Replacement: step 7, image 1 of 3 Logitech MX Keys for Mac Battery Replacement: step 7, image 2 of 3 Logitech MX Keys for Mac Battery Replacement: step 7, image 3 of 3
      • Plastic clips secure the battery cover.
      • Insert an opening pick between the top edge of the battery cover and keyboard.
      • Slide the pick along the top edge to release the clips.
      Ask FixBot
    4. Logitech MX Keys for Mac Battery Replacement: step 8, image 1 of 2 Logitech MX Keys for Mac Battery Replacement: step 8, image 2 of 2
      • Insert an opening pick between the bottom edge of battery cover and keyboard.
      • Slide the pick along the bottom edge to release the remaining clips.
      Ask FixBot
    5. Logitech MX Keys for Mac Battery Replacement: step 9, image 1 of 2 Logitech MX Keys for Mac Battery Replacement: step 9, image 2 of 2
      • Remove the battery cover.
      • During reassembly:
      • Place the battery cover onto the keyboard assembly so the screw holes line up with their posts.
      • Press down firmly along the battery cover to engage its clips.
      • You should feel and hear distinct "clicks" as the clips engage.
      Ask FixBot
    6. Logitech MX Keys for Mac Battery Replacement, Remove the battery: step 10, image 1 of 3 Logitech MX Keys for Mac Battery Replacement, Remove the battery: step 10, image 2 of 3 Logitech MX Keys for Mac Battery Replacement, Remove the battery: step 10, image 3 of 3
      $3.99
      Buy
      • Use a pair of angled tweezers to firmly grip the battery connector and slide it straight out of its socket.
      • If you're having trouble, gently rock the connector side-to-side to help loosen it.
      • Insert the connector into its socket so the side with raised plastic in the center is facing up.
      • Push on the edges of the connector with the flat end of a spudger until it's fully seated in the socket.
      Ask FixBot
    7. Logitech MX Keys for Mac Battery Replacement: step 11, image 1 of 2 Logitech MX Keys for Mac Battery Replacement: step 11, image 2 of 2
      • Pull the three battery cables out of their channel in the keyboard.
      • During reassembly, route all three cables through their channel so they're on top of each other.
      Ask FixBot
    8. Logitech MX Keys for Mac Battery Replacement: step 12, image 1 of 3 Logitech MX Keys for Mac Battery Replacement: step 12, image 2 of 3 Logitech MX Keys for Mac Battery Replacement: step 12, image 3 of 3
      • Insert the flat end of a spudger underneath the right edge of the battery, opposite the cables.
      • Slide the spudger underneath the battery and gently lift to separate the adhesive securing it to the keyboard.
      • Make sure you push the spudger underneath the battery and not into it. Don't bend or deform the battery.
      • If the battery isn't separating, apply a few drops of isopropyl alcohol (>90%) to its edge and slightly tilt the keyboard. Wait one minute for the alcohol to soften the adhesive and try again.
      • Remove the battery.
      Ask FixBot
    9. Logitech MX Keys for Mac Battery Replacement, Reassembly information: step 13, image 1 of 2 Logitech MX Keys for Mac Battery Replacement, Reassembly information: step 13, image 2 of 2
      Tesa 61395 Tape
      $8.95
      Buy
      • To install a replacement battery:
      • Remove any bits of the old adhesive from the battery recess.
      • If your replacement battery doesn't come with tape pre-installed, apply double-sided tape to the battery recess (not directly to the battery).
      • If your replacement battery has adhesive pre-installed, remove the plastic liner.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Spencer Day
207,062 Reputation
1,266 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 33
Past 30 Days: 101
All Time: 621
