Up to 20% off select tools
Logitech MX Keys Feet Replacement
Views: 7.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
76
Past 30 Days:
335
All Time:
7,507
Comments: 2
2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace worn-out or damaged feet (also known as skates, glides, slides, or pads) on your Logitech MX Keys wireless keyboard.
    1. Logitech MX Keys Feet Replacement, Prepare your keyboard for disassembly: step 1, image 1 of 3 Logitech MX Keys Feet Replacement, Prepare your keyboard for disassembly: step 1, image 2 of 3 Logitech MX Keys Feet Replacement, Prepare your keyboard for disassembly: step 1, image 3 of 3
      • Slide the keyboard's power switch into the OFF position.
      • A red indicator should be visible beneath the switch.
      • Unplug all cables from the keyboard.
      • Lay the keyboard down with the feet facing up on a clean work surface.
      • If your work surface may scratch the keyboard, place a soft towel under it.
      Ask FixBot
    2. Logitech MX Keys Feet Replacement, Heat the feet: step 2, image 1 of 2 Logitech MX Keys Feet Replacement, Heat the feet: step 2, image 2 of 2
      • Heat an iOpener and lay it on the top left foot for one minute.
      • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
      • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic.
      Ask FixBot
    3. Logitech MX Keys Feet Replacement, Remove the feet: step 3, image 1 of 3 Logitech MX Keys Feet Replacement, Remove the feet: step 3, image 2 of 3 Logitech MX Keys Feet Replacement, Remove the feet: step 3, image 3 of 3
      • The foot should come up without much force. If it feels stuck, apply more heat and try again.
      • Insert the point of a spudger under an end of the foot.
      • Push the spudger underneath the foot and lift until you can grip it with your fingers.
      • Peel the foot up and remove it.
      • Repeat the process to remove the remaining feet.
      • If you're replacing the battery, you only need to remove the feet along the top edge.
      Ask FixBot
    4. Logitech MX Keys Feet Replacement, Reassembly information: step 4, image 1 of 2 Logitech MX Keys Feet Replacement, Reassembly information: step 4, image 2 of 2
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • To install the feet during reassembly:
      • Use a pair of angled tweezers to peel up and remove all the plastic film from the foot recesses.
      • If you're installing new feet, remove them from their backing and firmly press them into place.
      • If you're reusing the feet, use a strip of double-sided tape to secure them in their recesses.
      Ask FixBot
2 other people completed this guide.
Author
with
Spencer Day
210,776 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
2 Guide Comments
Where do you buy replacement 'feet' for the MX Keys?
maxtraxpro - Reply Share
Hi, mooie uitleg.
Vraagje: Heeft iemand een idee waar ik de voetjes van een mx toetsenbord kan kopen? Bij mij bord zijn er twee uitgevallen.
En een geweldig initiatief is ifixit!
Groet Henk Volkers
Henk Volkers - Reply Share
Past 24 Hours: 5
Past 7 Days: 76
Past 30 Days: 335
All Time: 7,507
