Up to 20% off select tools
Logitech MX Ergo Battery Replacement
Views: 23K
View statistics:
Past 24 Hours:
13
Past 7 Days:
120
Past 30 Days:
534
All Time:
23,055
Comments: 8
1 comment on steps, 7 guide comments.
Go to guide comments
Completed: 19
19 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace a worn-out or dead battery in your MX Ergo wireless mouse.
It’s natural for batteries to lose capacity as they age. If your mouse dies quickly and doesn't hold a charge, it may be time to replace the battery.
For safety, perform this repair when your battery is below 15% charge. Any charged lithium-ion battery can be hazardous if punctured or damaged. If your battery looks puffy or swollen, take appropriate precautions.
    1. Logitech MX Ergo Battery Replacement, Power off your mouse: step 1, image 1 of 3 Logitech MX Ergo Battery Replacement, Power off your mouse: step 1, image 2 of 3 Logitech MX Ergo Battery Replacement, Power off your mouse: step 1, image 3 of 3
      • Before you begin, flip the mouse's power switch into the OFF position.
      • A red indicator should be visible beneath the switch.
      • Unplug all cables from your mouse.
      • Throughout your repair, it may be helpful to lay your mouse on a soft cloth to stabilize it and prevent damage while you work.
      Ask FixBot
    1. Logitech MX Ergo Battery Replacement, Remove the cover: step 2, image 1 of 2 Logitech MX Ergo Battery Replacement, Remove the cover: step 2, image 2 of 2
      • Remove the magnetic cover by pulling it away from the bottom of your mouse.
      Ask FixBot
    2. Logitech MX Ergo Battery Replacement, Remove the case screws: step 3, image 1 of 2 Logitech MX Ergo Battery Replacement, Remove the case screws: step 3, image 2 of 2
      • Use a Torx T6 screwdriver to remove the six 5.7 mm-long screws securing the two halves of the mouse together.
      Ask FixBot
    3. Logitech MX Ergo Battery Replacement, Remove the trackball: step 4, image 1 of 3 Logitech MX Ergo Battery Replacement, Remove the trackball: step 4, image 2 of 3 Logitech MX Ergo Battery Replacement, Remove the trackball: step 4, image 3 of 3
      • Insert a spudger into the hole on the bottom of the mouse, beneath the trackball.
      • Use the spudger to push the trackball out of its recess.
      • Remove the trackball.
      Ask FixBot
    4. Logitech MX Ergo Battery Replacement, Release the plastic clips: step 5, image 1 of 3 Logitech MX Ergo Battery Replacement, Release the plastic clips: step 5, image 2 of 3 Logitech MX Ergo Battery Replacement, Release the plastic clips: step 5, image 3 of 3
      • Clips around the perimeter of the mouse case hold the two halves together.
      • Insert the tip of an opening pick into the seam between the two halves, near the middle of the right edge.
      • Twist the opening pick to release the plastic clip.
      Ask FixBot
    5. Logitech MX Ergo Battery Replacement: step 6, image 1 of 2 Logitech MX Ergo Battery Replacement: step 6, image 2 of 2
      • Slide the opening pick along the seam until it's about half way to the rear of the mouse.
      • Twist the pick to release the plastic clip.
      Ask FixBot
    6. Logitech MX Ergo Battery Replacement: step 7, image 1 of 2 Logitech MX Ergo Battery Replacement: step 7, image 2 of 2
      • Slide the opening pick all the way to the rear the mouse.
      Ask FixBot
    7. Logitech MX Ergo Battery Replacement: step 8, image 1 of 2 Logitech MX Ergo Battery Replacement: step 8, image 2 of 2
      • Slide the opening pick to the middle of the left edge, next to the trackball recess.
      Ask FixBot
    8. Logitech MX Ergo Battery Replacement, Reposition the top half: step 9, image 1 of 3 Logitech MX Ergo Battery Replacement, Reposition the top half: step 9, image 2 of 3 Logitech MX Ergo Battery Replacement, Reposition the top half: step 9, image 3 of 3
      • Don't completely separate the two halves yet—they're still connected by a delicate cable.
      • Gently lift the top half and place it to the left of the mouse so you can access the internals.
      • Be careful not to strain any of the cables inside the mouse.
      Ask FixBot
    9. Logitech MX Ergo Battery Replacement, Disconnect the interconnect cable: step 10, image 1 of 3 Logitech MX Ergo Battery Replacement, Disconnect the interconnect cable: step 10, image 2 of 3 Logitech MX Ergo Battery Replacement, Disconnect the interconnect cable: step 10, image 3 of 3
      • Use the point of a spudger to gently lift alternating sides of the black sliding latch on the interconnect cable socket.
      • You should feel the latch pop into the unlocked position. Don't push too far, or the latch may come completely off the connector.
      Ask FixBot
    10. Logitech MX Ergo Battery Replacement: step 11, image 1 of 2 Logitech MX Ergo Battery Replacement: step 11, image 2 of 2
      • Use tweezers or your fingers to pull the interconnect cable straight up and out of its socket.
      Ask FixBot
    11. Logitech MX Ergo Battery Replacement, Remove the top half of the mouse: step 12, image 1 of 2 Logitech MX Ergo Battery Replacement, Remove the top half of the mouse: step 12, image 2 of 2
      • Lift the top half of the mouse straight up and remove it.
      Ask FixBot
    1. Logitech MX Ergo Battery Replacement, Disconnect the battery: step 13, image 1 of 2 Logitech MX Ergo Battery Replacement, Disconnect the battery: step 13, image 2 of 2
      • Use the pointed end of a spudger to push up on the battery connector, loosening it in its socket.
      • You don't need to push the connector completely out of its socket yet—you'll do so in a few steps.
      Ask FixBot
    2. Logitech MX Ergo Battery Replacement, Pry out the battery: step 14, image 1 of 3 Logitech MX Ergo Battery Replacement, Pry out the battery: step 14, image 2 of 3 Logitech MX Ergo Battery Replacement, Pry out the battery: step 14, image 3 of 3
      • Insert the long edge of an opening pick between the long edge of the battery and its housing, at the side opposite the battery cable.
      • Use your opening pick to pry up the battery and separate its adhesive. Apply steady, constant force and slide the pick farther under the battery as necessary.
      • Make sure you push the pick underneath the battery and not into it. Don't bend or deform the battery.
      Ask FixBot
    3. Logitech MX Ergo Battery Replacement: step 15, image 1 of 2 Logitech MX Ergo Battery Replacement: step 15, image 2 of 2
      • Use your fingers to lift the battery out of its housing.
      Ask FixBot
    4. Logitech MX Ergo Battery Replacement, Remove the battery: step 16, image 1 of 3 Logitech MX Ergo Battery Replacement, Remove the battery: step 16, image 2 of 3 Logitech MX Ergo Battery Replacement, Remove the battery: step 16, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • Use your fingers to grip the battery cables as close to the connector as possible and pull the connector straight up and out of its socket.
      • Remove the battery.
      • During reassembly:
      • Never install a deformed or damaged battery, as doing so is a potential safety hazard. Replace it with a new battery.
      • If the battery adhesive is still sticky, you can reuse it. Otherwise, remove all the old battery adhesive.
      • If your new battery has adhesive pre-installed, remove the plastic liner to expose the adhesive. Otherwise, apply strips of thin, double-sided tape to the battery well (not directly to the battery) where the old adhesive was.
      • Firmly press the battery into place, making sure the cables are on the side closest to their socket.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
19 other people completed this guide.
Author
with
Adriana Zwink
69,922 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
7 Guide Comments
This guide is fantastic! It was super easy to fix! Thanks!
Corey Trueman - Reply Share
Thank you for this !! Visited this site before for other tutorials you guys are great. This was easy to follow worked good for me.
DJSan - Reply Share
Its a very thorough explinations and guide except the most important point.
Where to buy the new replacement battery.
Jacob Bornman - Reply Share
Those are very well-done instructions. The new battery installation went very well. Thanks for the help.
Lyle Ellingson - Reply Share
hi where did you buy the battery?
Yanna - Reply Share
Past 24 Hours: 13
Past 7 Days: 120
Past 30 Days: 534
All Time: 23,055
