Logitech MX Anywhere 3S for Mac Battery Replacement
  1. Logitech MX Anywhere 3S for Mac Battery Replacement, Prepare the mouse for disassembly: step 1, image 1 of 2 Logitech MX Anywhere 3S for Mac Battery Replacement, Prepare the mouse for disassembly: step 1, image 2 of 2
    • Slide the mouse's power switch to the OFF position and unplug any cables.
    • Flip the mouse over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
  2. Logitech MX Anywhere 3S for Mac Battery Replacement, Soften the mouse feet adhesive: step 2, image 1 of 1
    • If you're planning to reuse your existing mouse feet, the adhesive needs to be thoroughly heated to cleanly remove them.
    • Heat an iOpener and lay it on the mouse feet for about two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic case.
  3. Logitech MX Anywhere 3S for Mac Battery Replacement, Disassembly information: step 3, image 1 of 3 Logitech MX Anywhere 3S for Mac Battery Replacement, Disassembly information: step 3, image 2 of 3 Logitech MX Anywhere 3S for Mac Battery Replacement, Disassembly information: step 3, image 3 of 3
    • While you wait for the adhesive to soften, note the following:
    • There are small gaps in the rims surrounding each foot. This is where to insert your tool when peeling up the feet.
  4. Logitech MX Anywhere 3S for Mac Battery Replacement, Remove the feet: step 4, image 1 of 3 Logitech MX Anywhere 3S for Mac Battery Replacement, Remove the feet: step 4, image 2 of 3 Logitech MX Anywhere 3S for Mac Battery Replacement, Remove the feet: step 4, image 3 of 3
    • Push the tip of an opening pick (or spudger) underneath the mouse foot, into the gap in the rim.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad—these layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • Slide your pick under the foot and lift to remove it.
    • Repeat the process to remove the three remaining mouse feet. If you're having trouble sliding the tool under a foot, reheat it and try again.
    • To install new mouse feet:
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive. Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet off their adhesive liners and press them firmly into place.
  5. Logitech MX Anywhere 3S for Mac Battery Replacement, Remove the case screws: step 5, image 1 of 2 Logitech MX Anywhere 3S for Mac Battery Replacement, Remove the case screws: step 5, image 2 of 2
    • Use a Phillips screwdriver to remove the four 4.3 mm‑long screws securing the two halves of the mouse together.
  6. Logitech MX Anywhere 3S for Mac Battery Replacement, Open the mouse: step 6, image 1 of 3 Logitech MX Anywhere 3S for Mac Battery Replacement, Open the mouse: step 6, image 2 of 3 Logitech MX Anywhere 3S for Mac Battery Replacement, Open the mouse: step 6, image 3 of 3
    • Gently lift the top shell off the mouse up and flip it over the right edge.
    • Don't try to fully remove the top shell yet—a cable connects it to the lower half.
  7. Logitech MX Anywhere 3S for Mac Battery Replacement, Disconnect the interconnect cable: step 7, image 1 of 2 Logitech MX Anywhere 3S for Mac Battery Replacement, Disconnect the interconnect cable: step 7, image 2 of 2
    • Use the point of a spudger or a clean fingernail to flip up the small, hinged locking flap on the interconnect cable ZIF connector (located on the underside of the top shell).
  8. Logitech MX Anywhere 3S for Mac Battery Replacement, Separate the cable adhesive: step 8, image 1 of 2 Logitech MX Anywhere 3S for Mac Battery Replacement, Separate the cable adhesive: step 8, image 2 of 2
    • There may be a small piece of adhesive securing the interconnect cable to the board on the top shell, right where the cable goes into its socket.
    • Apply a heated iOpener to the board on the underside of the mouse's top half for two minutes.
    • Gently slide the tip of an opening pick under the cable to separate its adhesive.
  9. Logitech MX Anywhere 3S for Mac Battery Replacement: step 9, image 1 of 2 Logitech MX Anywhere 3S for Mac Battery Replacement: step 9, image 2 of 2
    • Use your fingers or tweezers to pull the cable straight out of its socket.
    • During reassembly, insert the cable with its blue tab facing up, then flip down the locking flap.
  10. Logitech MX Anywhere 3S for Mac Battery Replacement, Remove the top half of the mouse: step 10, image 1 of 1
    • Remove the top shell.
  11. Logitech MX Anywhere 3S for Mac Battery Replacement, Reposition the wheel assembly cable: step 11, image 1 of 2 Logitech MX Anywhere 3S for Mac Battery Replacement, Reposition the wheel assembly cable: step 11, image 2 of 2
    • Use a pair of tweezers (or the point of a spudger) to lift the wheel assembly cables out from under their clip on the battery housing.
  12. Logitech MX Anywhere 3S for Mac Battery Replacement, Remove the battery housing screws: step 12, image 1 of 2 Logitech MX Anywhere 3S for Mac Battery Replacement, Remove the battery housing screws: step 12, image 2 of 2
    • Use a Phillips screwdriver to remove the three 3.4 mm‑long screws securing the battery housing.
  13. Logitech MX Anywhere 3S for Mac Battery Replacement, Expose the battery connector: step 13, image 1 of 2 Logitech MX Anywhere 3S for Mac Battery Replacement, Expose the battery connector: step 13, image 2 of 2
    • Be careful not to strain the battery cable.
    • Lift the battery housing up and set it aside so you can access the connector underneath.
    • If you're having trouble, make sure the scroll wheel cables are fully out of the way.
  14. Logitech MX Anywhere 3S for Mac Battery Replacement, Disconnect the battery: step 14, image 1 of 2 Logitech MX Anywhere 3S for Mac Battery Replacement, Disconnect the battery: step 14, image 2 of 2
    • Insert each arm of a pair of pointed tweezers into the small cutouts on the top of the battery connector socket.
    • Slowly push the connector out of its socket, just enough to grip the top of the connector with another pair of tweezers or your fingers.
    • Be careful not to let your tweezers slip out and damage the motherboard.
    • Pull the battery connector completely out of its socket to disconnect it.
  15. Logitech MX Anywhere 3S for Mac Battery Replacement, Remove the battery housing: step 15, image 1 of 2 Logitech MX Anywhere 3S for Mac Battery Replacement, Remove the battery housing: step 15, image 2 of 2
    • Remove the battery housing.
  16. Logitech MX Anywhere 3S for Mac Battery Replacement, Soften the battery adhesive: step 16, image 1 of 2 Logitech MX Anywhere 3S for Mac Battery Replacement, Soften the battery adhesive: step 16, image 2 of 2
    • The battery is secured in its housing with mild adhesive.
    • Flip the battery housing over so the battery is facing down.
    • Lay a heated iOpener on the battery housing for two minutes to soften the battery adhesive.
  17. Logitech MX Anywhere 3S for Mac Battery Replacement, Remove the battery: step 17, image 1 of 3 Logitech MX Anywhere 3S for Mac Battery Replacement, Remove the battery: step 17, image 2 of 3 Logitech MX Anywhere 3S for Mac Battery Replacement, Remove the battery: step 17, image 3 of 3
    Tool used on this step:
    Tesa 61395 Tape
    $8.95
    Buy
    • Be careful not not to bend, crease, deform, poke, or puncture the battery with your tool—a damaged battery is a potential fire hazard.
    • Insert the flat end of a spudger between the battery and its housing through one of the cutouts.
    • Use the spudger to pry the battery away from the housing to separate its adhesive.
    • Remove the battery.
    • To install a new battery:
    • Use tweezers or your fingers to peel all the old adhesive off the battery housing—it shouldn't leave any residue.
    • If your new battery doesn't come with adhesive pre‑installed, apply a couple strips of double-sided tape to the battery housing.
    • Orient your new battery so the sticker is facing up and the cables are on the short side of the housing that protrudes outward. Press the battery firmly into place to secure it.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Spencer Day
187,384 Reputation
1,187 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 63
All Time: 182
