Logitech MX Anywhere 3 for Mac Mouse Feet Replacement
  1. Logitech MX Anywhere 3 for Mac Mouse Feet Replacement, Prepare the mouse for disassembly: step 1, image 1 of 2 Logitech MX Anywhere 3 for Mac Mouse Feet Replacement, Prepare the mouse for disassembly: step 1, image 2 of 2
    • Slide the mouse's power switch to the OFF position and unplug any cables.
    • Flip the mouse over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    Ask FixBot
  2. Logitech MX Anywhere 3 for Mac Mouse Feet Replacement, Soften the mouse feet adhesive: step 2, image 1 of 1
    • If you're planning to reuse your existing mouse feet, the adhesive needs to be thoroughly heated to cleanly remove them.
    • Heat an iOpener and lay it on the mouse feet for about two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic case.
    Ask FixBot
  3. Logitech MX Anywhere 3 for Mac Mouse Feet Replacement, Disassembly information: step 3, image 1 of 3 Logitech MX Anywhere 3 for Mac Mouse Feet Replacement, Disassembly information: step 3, image 2 of 3 Logitech MX Anywhere 3 for Mac Mouse Feet Replacement, Disassembly information: step 3, image 3 of 3
    • While you wait for the adhesive to soften, note the following:
    • There are small gaps in the rims surrounding each foot. This is where to insert your tool when peeling up the feet.
    Ask FixBot
  4. Logitech MX Anywhere 3 for Mac Mouse Feet Replacement, Remove the feet: step 4, image 1 of 3 Logitech MX Anywhere 3 for Mac Mouse Feet Replacement, Remove the feet: step 4, image 2 of 3 Logitech MX Anywhere 3 for Mac Mouse Feet Replacement, Remove the feet: step 4, image 3 of 3
    • Push the tip of an opening pick (or spudger) underneath the mouse foot, into the gap in the rim.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad—these layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • Slide your pick under the foot and lift to remove it.
    • Repeat the process to remove the three remaining mouse feet. If you're having trouble sliding the tool under a foot, reheat it and try again.
    • To install new mouse feet:
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive. Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet off their adhesive liners and press them firmly into place.
    Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Clay Eickemeyer
105,388 Reputation
472 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
19,790 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 42
All Time: 777
