Up to 20% off select tools
Logitech MBJ58 Mouse Top Cover Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
109
All Time:
2,564
Comments: 4
4 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If the top cover of your Logitech MBJ58 Mouse is damaged or needs to be replaced, this guide will help you replace the top cover. By replacing the top cover, damage can be removed, comfort can be added, and the aesthetics of your mouse can be increased. For this repair, no special skills are required and should be a straightforward fix. When reattaching the new cover, be sure to not strip the screw and crack the cover by using too much pressure.
    1. Logitech MBJ58 Mouse Top Cover Replacement, Top cover: step 1, image 1 of 1
      • Hold the mouse so that the bottom is facing up.
      • Remove the single Phillips #1 screw from the bottom half of the mouse.
      Ask FixBot
    2. Logitech MBJ58 Mouse Top Cover Replacement: step 2, image 1 of 2 Logitech MBJ58 Mouse Top Cover Replacement: step 2, image 2 of 2
      • Place the mouse so that the bottom is resting against a hard surface.
      • Lift the top cover of the mouse gently, and remove it.
      Ask FixBot
3 other people completed this guide.
Author
with
Maximilian Betkowski
238 Reputation
4 Guides authored
Cal Poly, Team 5-14, Forte Winter 2013 Member of Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 109
All Time: 2,564
