Up to 20% off select tools
Logitech MBJ58 Mouse Buttons Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
99
All Time:
3,793
Comments: 4
4 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 4 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will walk you through the process of removing the top cover of the mouse to replace the mouse buttons.
    1. Logitech MBJ58 Mouse Buttons Replacement, Top cover: step 1, image 1 of 1
      • Hold the mouse so that the bottom is facing up.
      • Remove the single Phillips #1 screw from the bottom half of the mouse.
      Ask FixBot
    2. Logitech MBJ58 Mouse Buttons Replacement: step 2, image 1 of 2 Logitech MBJ58 Mouse Buttons Replacement: step 2, image 2 of 2
      • Place the mouse so that the bottom is resting against a hard surface.
      • Lift the top cover of the mouse gently, and remove it.
      Ask FixBot
    1. Logitech MBJ58 Mouse Buttons Replacement, Buttons: step 3, image 1 of 2 Logitech MBJ58 Mouse Buttons Replacement, Buttons: step 3, image 2 of 2
      • Locate the two tabs that are protruding from the button assembly.
      • Be careful not to break either of the two tabs by squeezing too hard.
      • Pinch the tabs together to free the buttons.
      Ask FixBot
    2. Logitech MBJ58 Mouse Buttons Replacement: step 4, image 1 of 2 Logitech MBJ58 Mouse Buttons Replacement: step 4, image 2 of 2
      • Remove the button assembly from the top cover by flipping the top cover upside down and pulling the button assembly downward and away from the top cover.
      • Slide the button assembly out from the top cover through the opening.
      • When fully disassembled, the top cover and the button assembly should look like this.
      Ask FixBot
2 other people completed this guide.
Author
with
Maximilian Betkowski
238 Reputation
4 Guides authored
Cal Poly, Team 5-14, Forte Winter 2013 Member of Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 99
All Time: 3,793
