Up to 20% off select tools
Logitech MBJ58 Mouse Button Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
74
All Time:
964
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Tools
    1. Logitech MBJ58 Mouse Button Replacement, Mouse button: step 1, image 1 of 1
      • Unfortunately, the left mouse button was 2x "sucked out" (button & the plastic pin over it)
      • Solution: Swap the button on the left with the mouse wheel button and - n small piece of office clip - for reinforcement - melt into the bottom of the pen.
      • YahooOoO - Looift widerer! Addendum: "mouse wheel click" Works by the way also - because there small springs ensure that the button does not "stick" in the pressed state
      Ask FixBot
      • Loosen the Phillips screw in the bottom.
      Ask FixBot
      • The plastic holder of the mouse buttons is loosened by carefully pressing the two plastic closures in the middle.
      • The motherboard is just plugged in and can be carefully removed forwards and upwards.
      Ask FixBot
      • Sensibly, first clean everything (dry).
      • Now click the button for "Links" with the button below the mouse wheel. The solder joints are huge and easy to get even for beginners.
      Ask FixBot
      • Everything should click together again and screws can be screwed back in. -> Loooift.
      Ask FixBot
Repeat the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Tho. Hummet
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 74
All Time: 964
