Up to 20% off select tools
Logitech M535 Disassembly
Views: 3.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
133
All Time:
3,823
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 4 minutes
Difficulty: Very easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
My little Logitech M535 fell out of my backpack and the bodywork split apart in the front. Just by pressing the two parts together there was no way to fix it and I didn’t want to replace it because it was still working just fine. So I took inspiration from the teardown guide of the Anywhere MX because I figured it was not going to be that different… in fact the construction of this mouse is way simpler than the MX!
    1. Logitech M535 Disassembly, Logitech M535: step 1, image 1 of 1
      • This is how the mouse looks like once fixed
      Ask FixBot
    2. Logitech M535 Disassembly, Open the battery box: step 2, image 1 of 1
      • Slide the cover open to get to the battery
      Ask FixBot
    3. Logitech M535 Disassembly: step 3, image 1 of 1
      • Pull the sticker inside of the battery box slowly: the glue is pretty strong and the space is tight. A butter knife works alright. You need to remove enough of the sticker to get to the bottom of the battery box.
      Ask FixBot
    4. Logitech M535 Disassembly: step 4, image 1 of 1
      • The little screw is approximately there (it occurred to me I should write a guide only after I closed the mouse).
      • Gently pull apart the top and the bottom at this stage with some care to avoid breaking the internal plastic.
      Ask FixBot
4 other people completed this guide.
Author
with
Sam Curti
239 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 133
All Time: 3,823
