Up to 20% off select tools
Logitech M500 Mouse scroll wheel removal
Views: 1.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
98
All Time:
1,495
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Logitech M500 Mouse scroll wheel removal, Remove rubber feet: step 1, image 1 of 2 Logitech M500 Mouse scroll wheel removal, Remove rubber feet: step 1, image 2 of 2
      • The screws are hidden under the four rubber feet on the underside of the mouse.
      • Carefully peel away each foot and its layer of adhesive, putting them to the side to replace later.
      Ask FixBot
    2. Logitech M500 Mouse scroll wheel removal, Remove the screws and top casing: step 2, image 1 of 2 Logitech M500 Mouse scroll wheel removal, Remove the screws and top casing: step 2, image 2 of 2
      • Unscrew the four Phillips #0 screws hidden by the feet.
      • The top casing should now come loose with just a shake.
      Ask FixBot
    3. Logitech M500 Mouse scroll wheel removal, Free the USB cable: step 3, image 1 of 2 Logitech M500 Mouse scroll wheel removal, Free the USB cable: step 3, image 2 of 2
      • Gently pull the USB cable out of its channel.
      Ask FixBot
    4. Logitech M500 Mouse scroll wheel removal, Unplug the USB cable: step 4, image 1 of 2 Logitech M500 Mouse scroll wheel removal, Unplug the USB cable: step 4, image 2 of 2
      • Grip the white plastic plug and remove it from its socket.
      • This may take some force. Try to pull straight upwards as much as possible, but it may help to wiggle the plug back and forth.
      Ask FixBot
    5. Logitech M500 Mouse scroll wheel removal, Remove the scroll wheel: step 5, image 1 of 3 Logitech M500 Mouse scroll wheel removal, Remove the scroll wheel: step 5, image 2 of 3 Logitech M500 Mouse scroll wheel removal, Remove the scroll wheel: step 5, image 3 of 3
      • The scroll wheel is held in place by a plastic pin. Pull it sideways to remove it.
      • Grip the scroll wheel assembly by the transparent part and lift it out.
      • Two small springs at the front of the mouse are held in place by this assembly. Be careful not to lose them when removing it.
      Ask FixBot
Author
with
Harry Cutts
1,651 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 98
All Time: 1,495
