Up to 20% off select tools
Logitech M500 Mouse Switch Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
61
Past 30 Days:
281
All Time:
3,728
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
The switches on a mouse wear out over time, and often start double-clicking from a single press. Luckily, replacing them is quite straightforward so long as you have a soldering iron and a way to remove solder.
When buying new switches, it is advisable to pay attention to the quality. The switches are sold in different quality levels. The quality indicates the number of clicks for which the switch is designed for. This is usually indicated on the switch by the number in brackets. Example: Omron D2FC-F-7N(20M)
This means: This switch is designed for 20 million clicks.
By this type of switch, the bandwidth ranges from about 10 / 20 / 50 / 60 million clicks. So if you plan to use your mouse for a long time, try to get a micro switch with a higher click number.
This limit on the number of possible clicks is also responsible for the failure of the switches. This is also seen in the fact that the left mouse button is often the first to fail, as it is generally the most used button on a mouse.
    1. Logitech M500 Mouse Switch Replacement, Remove rubber feet: step 1, image 1 of 2 Logitech M500 Mouse Switch Replacement, Remove rubber feet: step 1, image 2 of 2
      • The screws are hidden under the four rubber feet on the underside of the mouse.
      • Carefully peel away each foot and its layer of adhesive, putting them to the side to replace later.
      Ask FixBot
    2. Logitech M500 Mouse Switch Replacement, Remove the screws and top casing: step 2, image 1 of 2 Logitech M500 Mouse Switch Replacement, Remove the screws and top casing: step 2, image 2 of 2
      • Unscrew the four Phillips #0 screws hidden by the feet.
      • The top casing should now come loose with just a shake.
      Ask FixBot
    3. Logitech M500 Mouse Switch Replacement, Free the USB cable: step 3, image 1 of 2 Logitech M500 Mouse Switch Replacement, Free the USB cable: step 3, image 2 of 2
      • Gently pull the USB cable out of its channel.
      Ask FixBot
    4. Logitech M500 Mouse Switch Replacement, Unplug the USB cable: step 4, image 1 of 2 Logitech M500 Mouse Switch Replacement, Unplug the USB cable: step 4, image 2 of 2
      • Grip the white plastic plug and remove it from its socket.
      • This may take some force. Try to pull straight upwards as much as possible, but it may help to wiggle the plug back and forth.
      Ask FixBot
    5. Logitech M500 Mouse Switch Replacement, Remove the scroll wheel: step 5, image 1 of 3 Logitech M500 Mouse Switch Replacement, Remove the scroll wheel: step 5, image 2 of 3 Logitech M500 Mouse Switch Replacement, Remove the scroll wheel: step 5, image 3 of 3
      • The scroll wheel is held in place by a plastic pin. Pull it sideways to remove it.
      • Grip the scroll wheel assembly by the transparent part and lift it out.
      • Two small springs at the front of the mouse are held in place by this assembly. Be careful not to lose them when removing it.
      Ask FixBot
    1. Logitech M500 Mouse Switch Replacement, Remove scroll wheel mount: step 6, image 1 of 3 Logitech M500 Mouse Switch Replacement, Remove scroll wheel mount: step 6, image 2 of 3 Logitech M500 Mouse Switch Replacement, Remove scroll wheel mount: step 6, image 3 of 3
      • Remove the two screws that secure the plastic wheel mount in the centre of the circuit board.
      • You don't have to unscrew them all the way, just enough to free the wheel mount.
      • Lift the wheel mount off the circuit board.
      Ask FixBot
    2. Logitech M500 Mouse Switch Replacement, Remove metal piece: step 7, image 1 of 2 Logitech M500 Mouse Switch Replacement, Remove metal piece: step 7, image 2 of 2
      • Undo the two screws holding down the metal piece at the front of the mouse.
      • Remove the metal piece.
      Ask FixBot
    3. Logitech M500 Mouse Switch Replacement, Put the springs somewhere safe: step 8, image 1 of 1
      • Two springs sit in holes in the circuit board at the front of the mouse. Put them somewhere safe.
      Ask FixBot
    4. Logitech M500 Mouse Switch Replacement, Remove the circuit board: step 9, image 1 of 3 Logitech M500 Mouse Switch Replacement, Remove the circuit board: step 9, image 2 of 3 Logitech M500 Mouse Switch Replacement, Remove the circuit board: step 9, image 3 of 3
      • Remove the last screw holding down the circuit board (next to the hole left by the scroll wheel).
      • Remove the circuit board by lifting it up at the front.
      • There will be some resistance to lifting up the board, until the plastic that the wheel mount was screwed into snaps out of its holes in the circuit board.
      Ask FixBot
    1. Logitech M500 Mouse Switch Replacement, Desolder the old switch: step 10, image 1 of 2 Logitech M500 Mouse Switch Replacement, Desolder the old switch: step 10, image 2 of 2
      • Double-check that you're removing the switch that you intend to!
      • Remove the solder from the three pins of the old switch.
      • If you have one, a desoldering gun is the easiest tool to use. Otherwise, you could use a handheld desoldering pump or some desoldering braid along with a soldering iron.
      • Pull the old switch out of its holes. You may need to loosen any remaining drops of solder with a soldering iron while doing this.
      Ask FixBot
    2. Logitech M500 Mouse Switch Replacement, Solder the replacement switch: step 11, image 1 of 2 Logitech M500 Mouse Switch Replacement, Solder the replacement switch: step 11, image 2 of 2
      • Insert the new switch into the holes, being careful to put it in the right way around. The white button on the top of the switch should be closest to the front end of the circuit board.
      • Solder the new switch into place.
      • Before reassembling the mouse, you may wish to reconnect the USB cable, plug it into a computer, and check that the new switch works.
      Ask FixBot
2 other people completed this guide.
Author
with
Harry Cutts
1,651 Reputation
8 Guides authored
3 Guide Comments
Thank you very much for your great repair guide.
It helped me to put my Logitech M500 Mouse back together, after I had fixed it on my own beforehand.
DEsigner - Reply Share
Worked like a charm, getting the springs back in position was a pain in the *** though. You might want to make sure that your tools are not magnetized.
Markus29 - Reply Share
Thanks for this guide. Mostly works on the M500S too, but you need to remove a second screw close to the Logitech logo on the circuit board before you can remove it.
Albert Onestone - Reply Share
Past 24 Hours: 3
Past 7 Days: 61
Past 30 Days: 281
All Time: 3,728
