Up to 20% off select tools
Logitech M330 Wireless Mouse Wheel Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
43
Past 30 Days:
273
All Time:
1,436
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide shows how to replace the scroll wheel in a Logitech M330 Wireless Mouse.
Dust, debris, or a worn-out wheel can cause the scroll wheel to stick or lose sensitivity.
Learn how to safely disassemble your mouse and install a new scroll wheel.
Before you begin: Turn off the mouse and remove the battery to avoid damaging the device.
    1. Logitech M330 Wireless Mouse Wheel Replacement, Mouse Wheel: step 1, image 1 of 3 Logitech M330 Wireless Mouse Wheel Replacement, Mouse Wheel: step 1, image 2 of 3 Logitech M330 Wireless Mouse Wheel Replacement, Mouse Wheel: step 1, image 3 of 3
      • Turn your mouse over with the scroll wheel facing down.
      • Flip the ON/OFF switch on the bottom of the mouse to turn it off.
      • Slide the battery cover off.
      • Remove the battery and unplug the USB receiver.
      Ask FixBot
    2. Logitech M330 Wireless Mouse Wheel Replacement: step 2, image 1 of 3 Logitech M330 Wireless Mouse Wheel Replacement: step 2, image 2 of 3 Logitech M330 Wireless Mouse Wheel Replacement: step 2, image 3 of 3
      • Use tweezers to peel back the battery sticker cover.
      • Use a JIS #00 screwdriver to remove the single 3.1 mm screw from the battery well.
      Ask FixBot
    3. Logitech M330 Wireless Mouse Wheel Replacement: step 3, image 1 of 2 Logitech M330 Wireless Mouse Wheel Replacement: step 3, image 2 of 2
      • Insert a plastic spudger in the seam between the top and bottom shell, starting at the back edge.
      • Slide a plastic spudger or opening pick around the edge to carefully release the clips.
      • Gently remove the bottom plate from the top cover.
      Ask FixBot
    4. Logitech M330 Wireless Mouse Wheel Replacement: step 4, image 1 of 3 Logitech M330 Wireless Mouse Wheel Replacement: step 4, image 2 of 3 Logitech M330 Wireless Mouse Wheel Replacement: step 4, image 3 of 3
      • Use a JIS #00 screwdriver to remove the 1.5 mm screw securing the board to the case.
      • Gently remove board from bottom plate.
      Ask FixBot
    5. Logitech M330 Wireless Mouse Wheel Replacement: step 5, image 1 of 1
      • Gently remove the scroll wheel from the shaft, taking note of any spacer or washer arrangement.
      • Install the new wheel, ensuring it spins smoothly and provides the expected tactile click.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Adam Ward
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 43
Past 30 Days: 273
All Time: 1,436
