Up to 20% off select tools
Logitech M317C Mouse Switch Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
26
Past 30 Days:
109
All Time:
617
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Replace a worn out switch on your mouse.
    1. Logitech M317C Mouse Switch Replacement, Mouse Switch: step 1, image 1 of 1
      • The mouse before starting
      Ask FixBot
    2. Logitech M317C Mouse Switch Replacement: step 2, image 1 of 1
      • Flip over the mouse, removing the battery cover, USB receiver, and single Phillips 0 screw.
      Ask FixBot
    3. Logitech M317C Mouse Switch Replacement: step 3, image 1 of 1
      • Lift off the top cover of the mouse. No cables hold it in place.
      Ask FixBot
    4. Logitech M317C Mouse Switch Replacement: step 4, image 1 of 1
      • The board is held in place with several plastic clips. Use a spudger to gently push the clip next to the battery compartment. The board should raise slightly.
      Ask FixBot
    5. Logitech M317C Mouse Switch Replacement: step 5, image 1 of 1
      • Lift the board out of the mouse, towards the back of the mouse (note the clips in front).
      • Keep track of the power switch, as it may fall out when you remove the board. If it does, note the position of the on/off switch on the board and replace the switch.
      Ask FixBot
    6. Logitech M317C Mouse Switch Replacement: step 6, image 1 of 1
      • Desolder the 3 points of each switch as needed (upper and lower left solder points in photo).
      Ask FixBot
    7. Logitech M317C Mouse Switch Replacement: step 7, image 1 of 1
      • The original, non-clicking switch indicated.
      Ask FixBot
    8. Logitech M317C Mouse Switch Replacement: step 8, image 1 of 1
      • Solder the new switch into place, and reinsert the board.
      • Ensure all three clips hold the board in place, that the power switch is installed correctly, and the battery holder is inserted in the cavity at each end of the compartment.
      Ask FixBot
      • Reinstall the cover and test!
      Ask FixBot
Author
with
Jon
1,002 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 109
All Time: 617
