Up to 20% off select tools
Logitech M215 Top Cover Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
118
All Time:
3,688
Comments: 9
9 comments on steps.
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the top cover on your Logitech M215.
    1. Logitech M215 Top Cover Replacement, Remove the battery cover: step 1, image 1 of 3 Logitech M215 Top Cover Replacement, Remove the battery cover: step 1, image 2 of 3 Logitech M215 Top Cover Replacement, Remove the battery cover: step 1, image 3 of 3
      • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
      • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
      • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
      Ask FixBot
    2. Logitech M215 Top Cover Replacement, Remove old battery: step 2, image 1 of 1
      • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
      Ask FixBot
    1. Logitech M215 Top Cover Replacement, Top Cover: step 3, image 1 of 2 Logitech M215 Top Cover Replacement, Top Cover: step 3, image 2 of 2
      • The pads on the underside of the mouse hide the screws. Remove these first. You may need to use your fingernails or a prying tool.
      • There will be two 0.5mm phillips head screws. Both will be underneath the bottom two pads.
      Ask FixBot
    2. Logitech M215 Top Cover Replacement: step 4, image 1 of 1
      • Pry the top cover off. You may need to use a pry tool to help.
      Ask FixBot
Author
with
Hannah Pate
1,742 Reputation
7 Guides authored
USF Tampa, Team 1-1, Watkins Winter 2015 Member of USF Tampa, Team 1-1, Watkins Winter 2015
USFT-WATKINS-W15S1G1
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 118
All Time: 3,688
