Up to 20% off select tools
Logitech M185 Wireless Mouse Disassembly
Views: 46K
View statistics:
Past 24 Hours:
19
Past 7 Days:
156
Past 30 Days:
643
All Time:
46,136
Comments: 16
4 comments on steps, 12 guide comments.
Go to guide comments
Completed: 43
43 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 seconds - 2 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Logitech M185 Wireless Mouse Disassembly, Remove the Battery Cover and Battery: step 1, image 1 of 2 Logitech M185 Wireless Mouse Disassembly, Remove the Battery Cover and Battery: step 1, image 2 of 2
      • Remove battery cover by sliding it off.
      Ask FixBot
    2. Logitech M185 Wireless Mouse Disassembly, Unscrew: step 2, image 1 of 2 Logitech M185 Wireless Mouse Disassembly, Unscrew: step 2, image 2 of 2
      • Unscrew the Phillips #1 screw in the battery compartment after removing the battery.
      • Some mice have a smaller screw, directly down and to the side of the on/off slider. The rest of the disassembly is the same.
      Ask FixBot
    3. Logitech M185 Wireless Mouse Disassembly, Remove the top cover: step 3, image 1 of 1
      • There is no need to remove its rubber feet since it is held together by only one screw.
      • Wiggle the grey part of the top to remove it by pulling it towards you(away from the scroll wheel).
      • Do not pull the grey cover towards the top and do not pull the part near the keys.
      • Reasoning by Jacob Hickey "because in the internal top part of the mouse where the buttons/scroll wheel is, there’s hinges-like “tooth” that’ll snap if you do pull on it. It’s like opening a jewelry box that has a hinge on one end of the box… if that makes sense…"
      • The image is what your mouse should look like in the end.
      Ask FixBot
    4. Logitech M185 Wireless Mouse Disassembly, Remove Circuit Board: step 4, image 1 of 3 Logitech M185 Wireless Mouse Disassembly, Remove Circuit Board: step 4, image 2 of 3 Logitech M185 Wireless Mouse Disassembly, Remove Circuit Board: step 4, image 3 of 3
      • Push back small black clips to release the circuit board.
      • Slide up the metal battery connectors to free them from the casing. (Note that these are soldered to the circuit board.)
      • Fully remove the circuit board with the battery connectors and image sensor still attached.
      Ask FixBot
    5. Logitech M185 Wireless Mouse Disassembly, Separate top casing layers: step 5, image 1 of 3 Logitech M185 Wireless Mouse Disassembly, Separate top casing layers: step 5, image 2 of 3 Logitech M185 Wireless Mouse Disassembly, Separate top casing layers: step 5, image 3 of 3
      • Working from back to front (left to right in the first image) unclip the first two pairs of black plastic clips.
      • Slide the black upper casing forwards over the mouse wheel whilst applying pressure the two front clips to release them.
      • Separate the two casing layers fully.
      Ask FixBot
43 other people completed this guide.
Author
with
Karmanyaah Malhotra
1,185 Reputation
1 Guide authored
12 Guide Comments
Thank you Karmanyaah Malhotra for takin’ the time to do this for everybody like me :-)
Jacob Hickey - Reply Share
TElll me now or else
Brayden Karanian - Reply Share
I will be sad
Past 24 Hours: 19
Past 7 Days: 156
Past 30 Days: 643
All Time: 46,136
