Up to 20% off select tools
Logitech M100 USB Cable Replacement
Views: 7.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
165
All Time:
7,174
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will detail how to disassemble a Logitech M100 mouse and replace its USB cable. This process is relatively universal, so it can be applied to a number of similar mice.
    1. Logitech M100 USB Cable Replacement, USB Cable: step 1, image 1 of 2 Logitech M100 USB Cable Replacement, USB Cable: step 1, image 2 of 2
      • Not all variants of this mouse require the mouse feet to be taken off for disassembly, but their removal is detailed anyway.
      • Carefully remove the feet of the mouse with an opening pick.
      • Keep track of the mouse feet, as you'll be reapplying them at the end of the guide.
      Ask FixBot
    2. Logitech M100 USB Cable Replacement: step 2, image 1 of 2 Logitech M100 USB Cable Replacement: step 2, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the 10mm screws on the bottom of the mouse.
      • Once all screws are removed, use the plastic opening tool to gently pry the mouse apart. This shouldn't take much force.
      Ask FixBot
    3. Logitech M100 USB Cable Replacement: step 3, image 1 of 2 Logitech M100 USB Cable Replacement: step 3, image 2 of 2
      • Once the mouse is opened, locate the USB cable's 5-pin connector, which is plugged directly into the mouse's mainboard.
      • Take note of the position and route that the USB cable takes before removal. The replacement cable must follow the same route when inserted.
      • Using a plastic opening tool, gently remove the 5-pin connector from the mainboard.
      Ask FixBot
    4. Logitech M100 USB Cable Replacement: step 4, image 1 of 2 Logitech M100 USB Cable Replacement: step 4, image 2 of 2
      • Take the replacement USB cable and connect it to the mainboard.
      Ask FixBot
    5. Logitech M100 USB Cable Replacement: step 5, image 1 of 2 Logitech M100 USB Cable Replacement: step 5, image 2 of 2
      • Ensure that the 5-pin connector is fully seated into its slot on the mainboard. You may want to use a spudger to apply pressure onto it.
      • Using a plastic opening tool, route the cable through the case in the same way that was noted in Step 3.
      Ask FixBot
    6. Logitech M100 USB Cable Replacement: step 6, image 1 of 1
      • After re-assembling the mouse, don't forget to reattach the mouse feet onto their correct locations on the bottom of the mouse.
      Ask FixBot
To reassemble, follow the steps in reverse order.
4 other people completed this guide.
Author
with
Jake Janicke
161 Reputation
1 Guide authored
1 Guide Comment
Removing the mouse feet is completely unnecessary, as there are no screws underneath the feet.
Andy Joonseo Bae - Reply Share
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 165
All Time: 7,174
