Up to 20% off select tools
Logitech K860 Disassembly
Views: 12K
View statistics:
Past 24 Hours:
8
Past 7 Days:
80
Past 30 Days:
366
All Time:
12,469
Comments: 14
5 comments on steps, 9 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Difficult
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This disassembly will show you how to get into your Logitech K860.
    1. Logitech K860 Disassembly, Keyboard: step 1, image 1 of 2 Logitech K860 Disassembly, Keyboard: step 1, image 2 of 2
      • Remove all visible screws from the base of the keyboard.
      • Keep all of the screws together. As you remove a screw, note that it matches the other removed screws, and keep the same screws together. Oftentimes, there are 2 or 3 screws that are different. Keep those separate, document where they go.
      • There will be hidden screws under the plastic feet and underneath the serial number sticker. This is designed as an irreversible tamper protection seal. void your warranty. This screw needs to be removed.
      • As a general warning, this is a difficult item to repair, and the likelihood of success is low if you are trying to access the keyboard's membrane. There are fragile plastic supports ahead; you will need to take care.
      Ask FixBot
    2. Logitech K860 Disassembly: step 2, image 1 of 2 Logitech K860 Disassembly: step 2, image 2 of 2
      • After removing the screws from the base, you will be able to remove the wrist pad, which will reveal the other half of the battery compartment with more screws to remove.
      • Anyway, you need to unclip the wrist pad and unscrew some stuff again. Like 4-5 screws here.
      Ask FixBot
    3. Logitech K860 Disassembly: step 3, image 1 of 1
      • As the frame comes apart, be mindful that they are connected via this on/off switch. Carefully wiggle one of the connectors to unplug, and set the base aside.
      • This is where it becomes difficult. Scattered around the metal sheet are dark grey plastic supports that have been melted during assembly.
      • They are essentially hot rivets and are cheaper than screws. Each one is shaped initially as a cylinder or pillar. During assembly at the factory, after the metal plate is installed, these are all pressed down with heat to mildly melt them, resulting in a slight mushroom head, which is visible to you here.
      • To unattach the plate, we need to break each one with a sharp knife, by cracking and lifting away some of the flattened, mushroomed 'head'. While this is irreversible, it will not prevent the operation of the keyboard. Later, the screws that have already been removed will now bear the entire load of holding these components together.
      Ask FixBot
    4. Logitech K860 Disassembly: step 4, image 1 of 1
      • Now you are left with this beautiful view. You can unscrew the ground for the small board and the board itself. You can even unscrew 2 screws on either side of the keyboard.
      • What remains is the key membrane assembly, which is, arguably, designed to be non-replaceable and non-repairable. [Which prompts the reader to ask why does this guide exist at all? -Ed.]
      Ask FixBot
10 other people completed this guide.
Author
with
AlexG
316 Reputation
1 Guide authored
9 Guide Comments
Great guide! the part about the hidden screw under the serial number in particular was a life saver.
One thing that's not clear is which slots take the smaller vs the larger screws, it would help to annotate that as now I'm blindly screwing whatever fits.
michaelchirico4 - Reply Share
OK so IINM, the 6 small screws all go on the upper half of the reverse side. There is also one slot for a longer screw (closest to the power switch). Anyway the longer screws don't fit in the small slots so it's easy.
Great guide. But I have 2 buttons that are not working, if it can not get to te membrane how can i test it or clean it?
Victor Araki Miyazono - Reply Share
that's ridiculous that you can't do that. I have the same issue.
Artan Muzhaqi - Reply Share
some water was dropped into keyboard and some keys is not working anymore. Indeed, if it now possible to see the membrane or too much hard to put it back, it seems does not make any sense to fix it. Logitech wins...
Ferreira - Reply Share
Past 24 Hours: 8
Past 7 Days: 80
Past 30 Days: 366
All Time: 12,469
