Up to 20% off select tools
Logitech K800 Battery Replacement
Views: 36K
View statistics:
Past 24 Hours:
10
Past 7 Days:
82
Past 30 Days:
447
All Time:
36,211
Comments: 27
5 comments on steps, 22 guide comments.
Go to guide comments
Completed: 23
23 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the battery in a Logitech K800 wireless keyboard.
For your safety, discharge the battery below 25% before disassembling your keyboard. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
    1. Logitech K800 Battery Replacement, Remove the rear compartment screw: step 1, image 1 of 1
      • Use a Phillips driver to remove the 5.7 mm screw securing the rear compartment.
      Ask FixBot
    2. Logitech K800 Battery Replacement, Remove the rear compartment: step 2, image 1 of 3 Logitech K800 Battery Replacement, Remove the rear compartment: step 2, image 2 of 3 Logitech K800 Battery Replacement, Remove the rear compartment: step 2, image 3 of 3
      • Slide the rear compartment toward the top of the keyboard and remove it.
      Ask FixBot
    3. Logitech K800 Battery Replacement, Pry up the rear cover: step 3, image 1 of 2 Logitech K800 Battery Replacement, Pry up the rear cover: step 3, image 2 of 2
      • Slide the edge of an opening tool underneath the bottom edge of the rear cover and pry the cover up to create a gap.
      • You will pry the rear cover away from the keyboard for the next two steps. There are adhesive and clips holding the cover down that will make prying difficult.
      Ask FixBot
    4. Logitech K800 Battery Replacement, Continue prying the rear cover: step 4, image 1 of 3 Logitech K800 Battery Replacement, Continue prying the rear cover: step 4, image 2 of 3 Logitech K800 Battery Replacement, Continue prying the rear cover: step 4, image 3 of 3
      • Keeping the opening tool under the rear cover, slide it around the right side of the cover to separate the adhesive and clips on that side.
      • It may help to push the tool farther under the cover, toward the middle of the keyboard.
      Ask FixBot
    5. Logitech K800 Battery Replacement: step 5, image 1 of 3 Logitech K800 Battery Replacement: step 5, image 2 of 3 Logitech K800 Battery Replacement: step 5, image 3 of 3
      • Keeping the opening tool under the rear cover, slide it around the left side of the cover to separate the adhesive and clips on that side.
      Ask FixBot
    6. Logitech K800 Battery Replacement, Remove the rear cover: step 6, image 1 of 3 Logitech K800 Battery Replacement, Remove the rear cover: step 6, image 2 of 3 Logitech K800 Battery Replacement, Remove the rear cover: step 6, image 3 of 3
      • Hinge the bottom of the rear cover up until the clips along the top edge of the cover disengage, then lift the whole cover up to remove it.
      Ask FixBot
    7. Logitech K800 Battery Replacement, Reassembly tip: step 7, image 1 of 3 Logitech K800 Battery Replacement, Reassembly tip: step 7, image 2 of 3 Logitech K800 Battery Replacement, Reassembly tip: step 7, image 3 of 3
      • During reassembly, start by sliding the clips along the top edge of the rear cover into place.
      • Place the top edge of the cover slightly above the top edge of the keyboard, then slide it down into place.
      Ask FixBot
    8. Logitech K800 Battery Replacement, Remove the front cover: step 8, image 1 of 1
      • Use a Phillips driver to remove the fourteen 5.7 mm screws securing the front cover.
      • Use a Phillips driver to remove the three 4.7 mm screws securing the keyboard keys.
      Ask FixBot
    9. Logitech K800 Battery Replacement: step 9, image 1 of 2 Logitech K800 Battery Replacement: step 9, image 2 of 2
      • Slide an opening tool into the seam along one edge of the front cover. Pry the cover up to create a gap.
      Ask FixBot
    10. Logitech K800 Battery Replacement: step 10, image 1 of 3 Logitech K800 Battery Replacement: step 10, image 2 of 3 Logitech K800 Battery Replacement: step 10, image 3 of 3
      • Slide the opening tool around the perimeter of the front case to release all the clips securing the front cover.
      Ask FixBot
    11. Logitech K800 Battery Replacement: step 11, image 1 of 1
      • With all the clips released, lift the front cover and remove it.
      Ask FixBot
    12. Logitech K800 Battery Replacement, Unscrew the keyboard keys: step 12, image 1 of 1
      • Use a Phillips driver to remove the six screws securing the keyboard keys.
      • Four 5.7 mm screws
      • Two 4.7 mm screws
      Ask FixBot
    13. Logitech K800 Battery Replacement, Move the keyboard keys out of the way: step 13, image 1 of 2 Logitech K800 Battery Replacement, Move the keyboard keys out of the way: step 13, image 2 of 2
      • Gently flip the keyboard keys up and over the top of the keyboard to reveal the backlight.
      • Take care not to strain or crease the keyboard keys ribbon cable.
      Ask FixBot
    14. Logitech K800 Battery Replacement, Move the backlight out of the way: step 14, image 1 of 2 Logitech K800 Battery Replacement, Move the backlight out of the way: step 14, image 2 of 2
      • Gently flip the backlight up and over the top of the keyboard to reveal the keyboard backplate.
      • Take care not to strain or crease the backlight ribbon cable.
      Ask FixBot
    15. Logitech K800 Battery Replacement, Remove the backplate: step 15, image 1 of 3 Logitech K800 Battery Replacement, Remove the backplate: step 15, image 2 of 3 Logitech K800 Battery Replacement, Remove the backplate: step 15, image 3 of 3
      • Grasp one end of the backplate and lift it off of the keyboard case.
      • Remove the backplate.
      Ask FixBot
    16. Logitech K800 Battery Replacement, Disconnect the battery: step 16, image 1 of 2 Logitech K800 Battery Replacement, Disconnect the battery: step 16, image 2 of 2
      • Grasp the top edge of the battery connector with your fingers or a tweezer.
      • Pull the connector straight out of its socket on the motherboard.
      Ask FixBot
    17. Logitech K800 Battery Replacement, Free the battery cable: step 17, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to remove the tape securing the battery cable to the case.
      Ask FixBot
    18. Logitech K800 Battery Replacement: step 18, image 1 of 3 Logitech K800 Battery Replacement: step 18, image 2 of 3 Logitech K800 Battery Replacement: step 18, image 3 of 3
      • Pull the battery cable out of its slots in the keyboard case.
      Ask FixBot
    19. Logitech K800 Battery Replacement, Remove the battery: step 19, image 1 of 1
      • Heat an iOpener and apply it to the keyboard case underneath the battery for two minutes.
      Ask FixBot
    20. Logitech K800 Battery Replacement: step 20, image 1 of 3 Logitech K800 Battery Replacement: step 20, image 2 of 3 Logitech K800 Battery Replacement: step 20, image 3 of 3
      • Use a spudger to pry the battery away from the keyboard case.
      • If you encounter significant resistance, stop and apply more heat.
      Ask FixBot
    21. Logitech K800 Battery Replacement: step 21, image 1 of 1
      • Remove the battery.
      • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
      • During reassembly, you may use the old battery adhesive with your new battery. Alternatively, you may clean any old adhesive residue from the battery compartment using high-concentration isopropyl alcohol and install new adhesive from a follow pre-cut adhesive sheet.
      Ask FixBot
23 other people completed this guide.
Author
with
Adam O'Camb
226,699 Reputation
415 Guides authored
22 Guide Comments
the original took 2 lithium AA rechargeables. their update just creates ewaste
Kevin Weldon - Reply Share
not lithium! Just standard Ni-MH AA's. I was pretty disappointed when I bought the second keyboard (the fist one was already pretty beaten up) only to discover that below the battery door there is just plastic and no battery! bastards... I used the keyboard from time to time as 2xAA charger (as most of the time it was connected to power) and I swapped those fully charged batteries with discharged ones from other devices that take 2xAAs aswell
Nellinka Fotky - Reply Share
Do you have a part number for the replacement battery?
Ryker Bailey - Reply Share
https://www.canadianbatteries.com/logite...
Search engines are your friend
Gord N - Reply Share
The part in the canadianbatteries.com link is not the correct part for this keyboard.
The correct PN is 533-000141, this has longer leads on the battery and the battery capacity is larger than the one linked. Aliexpress is the only place I have been able to locate a new one.
Past 24 Hours: 10
Past 7 Days: 82
Past 30 Days: 447
All Time: 36,211
