Introduction
This guide will show you how to replace the flex circuit in your Logitech K480 keyboard. A flex circuit is used as a connector between electrical components when saving space and flexibility are most important in a device. A flex circuit might need to be replaced if the components are not connecting properly or if the circuit is damaged. The circuit is fragile and easily torn or bent, so be gentle when handling it.
Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
Slide a blue pick in to keep the pieces apart while you work on other areas.
Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
Remove the eight 3 mm screws using a Phillips #00 screwdriver
Remove the five 2 mm silver screws from the metal plate using a Phillips #00 screwdriver.
Remove the single 4 mm black screw by the motherboard using a Phillips #00 screwdriver.
Remove the two black 4 mm screws from the motherboard with a Phillips #00 screwdriver.
3 other people completed this guide.
