Up to 20% off select tools
Logitech K480 Easy-Switch Dial Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
13
Past 30 Days:
91
All Time:
920
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
The Logitech K480 Easy-Switch dial is responsible for switching between previously paired Bluetooth devices. The dial may need to be replaced if it's been structurally compromised, such as cracked or disconnected. You also may need to replace the dial if it is missing from your device. This guide will walk you through the disassembly and removal of your Logitech K480 Easy-Switch dial.
    1. Logitech K480 Easy-Switch Dial Replacement, Back Cover: step 1, image 1 of 1
      • Flip the keyboard over.
      Ask FixBot
    2. Logitech K480 Easy-Switch Dial Replacement: step 2, image 1 of 3 Logitech K480 Easy-Switch Dial Replacement: step 2, image 2 of 3 Logitech K480 Easy-Switch Dial Replacement: step 2, image 3 of 3
      • Remove the four rubber feet with a spudger.
      Ask FixBot
    3. Logitech K480 Easy-Switch Dial Replacement: step 3, image 1 of 3 Logitech K480 Easy-Switch Dial Replacement: step 3, image 2 of 3 Logitech K480 Easy-Switch Dial Replacement: step 3, image 3 of 3
      • Slide open battery panel.
      • Remove the batteries.
      Ask FixBot
    4. Logitech K480 Easy-Switch Dial Replacement: step 4, image 1 of 2 Logitech K480 Easy-Switch Dial Replacement: step 4, image 2 of 2
      • Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
      Ask FixBot
    5. Logitech K480 Easy-Switch Dial Replacement: step 5, image 1 of 2 Logitech K480 Easy-Switch Dial Replacement: step 5, image 2 of 2
      • Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
      Ask FixBot
    6. Logitech K480 Easy-Switch Dial Replacement: step 6, image 1 of 3 Logitech K480 Easy-Switch Dial Replacement: step 6, image 2 of 3 Logitech K480 Easy-Switch Dial Replacement: step 6, image 3 of 3
      • Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
      • Slide a blue pick in to keep the pieces apart while you work on other areas.
      • Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
      • The loud snaps are the clips that hold the pieces together. They're not breaking and you do not need to be alarmed.
      Ask FixBot
    1. Logitech K480 Easy-Switch Dial Replacement, Metal Plate: step 7, image 1 of 3 Logitech K480 Easy-Switch Dial Replacement, Metal Plate: step 7, image 2 of 3 Logitech K480 Easy-Switch Dial Replacement, Metal Plate: step 7, image 3 of 3
      • Remove the eight 3 mm screws using a Phillips #00 screwdriver
      • Remove the five 2 mm silver screws from the metal plate using a Phillips #00 screwdriver.
      • Remove the single 4 mm black screw by the motherboard using a Phillips #00 screwdriver.
      Ask FixBot
    2. Logitech K480 Easy-Switch Dial Replacement: step 8, image 1 of 2 Logitech K480 Easy-Switch Dial Replacement: step 8, image 2 of 2
      • Lift up and remove the metal plate.
      Ask FixBot
    1. Logitech K480 Easy-Switch Dial Replacement, Easy-Switch Dial: step 9, image 1 of 1
      • Remove the two black 4 mm screws from the dial motherboard located on the upper right corner of the device with the Phillips #00 screwdriver.
      Ask FixBot
    2. Logitech K480 Easy-Switch Dial Replacement: step 10, image 1 of 2 Logitech K480 Easy-Switch Dial Replacement: step 10, image 2 of 2
      • Lift the Easy-Switch motherboard up to pop it out from the dial.
      Ask FixBot
    3. Logitech K480 Easy-Switch Dial Replacement: step 11, image 1 of 3 Logitech K480 Easy-Switch Dial Replacement: step 11, image 2 of 3 Logitech K480 Easy-Switch Dial Replacement: step 11, image 3 of 3
      • Pop out the Easy-Switch dial by gently pressing your finger on the underside of of the dial.
      Ask FixBot
Author
with
Marie Sewell
354 Reputation
2 Guides authored
1 Guide Comment
Very good tutorial, it's a shame we don't know where to get the Logitech K480 Easy-Switch Dial part. Sincerely.
Herve SPADACINI - Reply Share
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 91
All Time: 920
