Up to 20% off select tools
Logitech K480 Back Cover Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
135
All Time:
1,466
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If you need to open up your Logitech K480, follow this guide.
    1. Logitech K480 Back Cover Replacement, Back Cover: step 1, image 1 of 1
      • Flip the keyboard over.
      Ask FixBot
    2. Logitech K480 Back Cover Replacement: step 2, image 1 of 3 Logitech K480 Back Cover Replacement: step 2, image 2 of 3 Logitech K480 Back Cover Replacement: step 2, image 3 of 3
      • Remove the four rubber feet with a spudger.
      Ask FixBot
    3. Logitech K480 Back Cover Replacement: step 3, image 1 of 3 Logitech K480 Back Cover Replacement: step 3, image 2 of 3 Logitech K480 Back Cover Replacement: step 3, image 3 of 3
      • Slide open battery panel.
      • Remove the batteries.
      Ask FixBot
    4. Logitech K480 Back Cover Replacement: step 4, image 1 of 2 Logitech K480 Back Cover Replacement: step 4, image 2 of 2
      • Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
      Ask FixBot
    5. Logitech K480 Back Cover Replacement: step 5, image 1 of 2 Logitech K480 Back Cover Replacement: step 5, image 2 of 2
      • Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
      Ask FixBot
    6. Logitech K480 Back Cover Replacement: step 6, image 1 of 3 Logitech K480 Back Cover Replacement: step 6, image 2 of 3 Logitech K480 Back Cover Replacement: step 6, image 3 of 3
      • Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
      • Slide a blue pick in to keep the pieces apart while you work on other areas.
      • Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
      • The loud snaps are the clips that hold the pieces together. They're not breaking and you do not need to be alarmed.
      Ask FixBot
3 other people completed this guide.
Author
with
Madison
778 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 135
All Time: 1,466
