Logitech K400r Wireless Keyboard Disassembly & Cleaning
    1. Logitech K400r Wireless Keyboard Disassembly & Cleaning, Keyboard: step 1, image 1 of 1
      • Use a small Phillips head screwdriver to unscrew all visible screws on the back of the keyboard.
      • Keep all screws in a safe place for easy reassembly.
      • Ensure the keyboard is shut off before disassembly.
      Ask FixBot
    2. Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 2, image 1 of 2 Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 2, image 2 of 2
      • Remove the battery port so the batteries are exposed, then take them out.
      • Unscrew the screw in the battery port.
      Ask FixBot
    3. Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 3, image 1 of 2 Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 3, image 2 of 2
      • Remove the two rubber pieces from the top of the keyboard.
      • Unscrew the screws located under the rubber pieces.
      Ask FixBot
    4. Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 4, image 1 of 1
      • Unscrew the screws located under the label in the center of the back of the keyboard.
      Ask FixBot
    5. Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 5, image 1 of 2 Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 5, image 2 of 2
      • Once you have removed all screws from the exterior, the keyboard should be able to split open and come apart.
      • Carefully pry open the keyboard. You can use your screwdriver or any prying tool.
      Ask FixBot
    6. Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 6, image 1 of 2 Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 6, image 2 of 2
      • Remove the key matrix, which is soft and should be clear or white.
      • Using a dry cloth, lightly wipe off the key matrix.
      Ask FixBot
    7. Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 7, image 1 of 1
      • Using a dry cotton swab, lightly dust off the mousepad and the area around the keys on the outside of the board.
      Ask FixBot
    8. Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 8, image 1 of 2 Logitech K400r Wireless Keyboard Disassembly & Cleaning: step 8, image 2 of 2
      • Using compressed air, dust is removed between the key switches and inside the circuit grid.
      Ask FixBot
      • After you have cleaned all components of your keyboard, place the key matrix, key switchboard, and circuit grid back inside the keyboard.
      • Place all screws back into the exterior of the keyboard and screw them in tightly.
      • Place batteries back in the battery compartment and close the battery port.
      • The keyboard is reassembled!
      Ask FixBot
Finish Line
5 other people completed this guide.
Dustie Flowers
283 Reputation
1 Guide authored
1 Guide Comment
Thanks for the guide.
Should be noted that on newer/older (?) boards, the battery compartment is different, and doesn't have a screw in the middle. Instead a screw is hidden under the little serial number to the side of the battery compartment. there is however no sticker on the middle of the back hiding two screws.
You can also remove the keys, by depressing the two snap-in hooks from the back-side. I had to do this as the stablizer on my enter key (ISO layout) wasn't properly on.
EDIT: Just realized I have a K400 plus. Well those are the only differences, so this guide pretty much applies to that too! :)
Mikkel Jeppesen - Reply Share
Past 24 Hours: 7
Past 7 Days: 42
Past 30 Days: 181
All Time: 5,800
