Introduction
This guide will show you how to fully deep clean a Logitech K360 keyboard, with individual key removal process!
Flip the keyboard face down, so that the keys are not visible. On this side, a detachable battery compartment cover will be visible. Once identified, ensure that the batteries are removed from the keyboard to ensure safety for yourself.
To properly clean the keys, soapy water will be made by using one cup of water, one tablespoon of baking soda, and one tablespoon of soap. Add together in a desired bowl and stir until uniform.
Once the soapy water is homogenous, add the individual keys and let them sit in the mixture for 30 minutes.
7 other people completed this guide.
2 Guide Comments
Have you happened to open up and see what is the switch issue? I've read on other sites some have received what sounds like not functioning keyboard that I'm guessing is due to the switch, since in my situation the switch seems to be not moving as freely as my other logitech keyboards and mice with the similar looking switch. Albeit mine is white and there doesn't appears to be an LED. Looks like there are what reads as Apple looking green color side of the switch for on and a redish-orange color side for off.
If you want to clean it, you need to disassemble it. That glossy area between the keys is a giant sticker...peel that off, and it will reveal screws and you can disassemble the keyboard, and clean it.
