Up to 20% off select tools
Logitech K345 Membrane Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
6
Past 7 Days:
20
Past 30 Days:
124
All Time:
1,307
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Are your Logitech MK345 keyboard keys not registering when pressed? If so, here is the repair guide for replacing your keyboard membrane. A keyboard membrane completes the circuit when a key is pressed, thus registering it, and providing feedback. It also protects the underlying circuitry from dust, debris, and spills, extending the life of the keyboard. If you haven't already looked at our troubleshooting guide for this issue, it's linked here. Make sure you turn off your keyboard and remove the batteries before beginning the repairs, so there is no energy going through the keyboard and thus no risk of electrocution.
    1. Logitech K345 Membrane Replacement, Battery: step 1, image 1 of 2 Logitech K345 Membrane Replacement, Battery: step 1, image 2 of 2
      • Gently flip over your keyboard so that the keys are facing down.
      Ask FixBot
    2. Logitech K345 Membrane Replacement: step 2, image 1 of 3 Logitech K345 Membrane Replacement: step 2, image 2 of 3 Logitech K345 Membrane Replacement: step 2, image 3 of 3
      • Slide open the battery compartment on the bottom of the keyboard.
      Ask FixBot
    3. Logitech K345 Membrane Replacement: step 3, image 1 of 1
      • Remove batteries from the compartment.
      Ask FixBot
    1. Logitech K345 Membrane Replacement, Membrane: step 4, image 1 of 1
      • Remove the thirteen 5.3 mm screws from the back of the keyboard using a Phillips #1 screwdriver.
      Ask FixBot
    2. Logitech K345 Membrane Replacement: step 5, image 1 of 2 Logitech K345 Membrane Replacement: step 5, image 2 of 2
      • Pry up the corner rubber pads using a Jimmy.
      Ask FixBot
    3. Logitech K345 Membrane Replacement: step 6, image 1 of 2 Logitech K345 Membrane Replacement: step 6, image 2 of 2
      • Remove the two 5.3 mm screws from the corners with a Phillips #1 screwdriver.
      Ask FixBot
    4. Logitech K345 Membrane Replacement: step 7, image 1 of 2 Logitech K345 Membrane Replacement: step 7, image 2 of 2
      • Use your hands and opening picks to remove the back of the keyboard.
      Ask FixBot
    5. Logitech K345 Membrane Replacement: step 8, image 1 of 3 Logitech K345 Membrane Replacement: step 8, image 2 of 3 Logitech K345 Membrane Replacement: step 8, image 3 of 3
      • Remove the keyboard membrane.
      Ask FixBot
Author
with
Aumirius Robinson
616 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 124
All Time: 1,307
