Up to 20% off select tools
Logitech K120 Keyboard Disassembly
Views: 15K
View statistics:
Past 24 Hours:
11
Past 7 Days:
60
Past 30 Days:
291
All Time:
14,701
Comments: 4
4 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
  • Spudger
    4.9
  • Phillips PH000 Screwdriver
    4.9
Introduction
Go to step 1 ↓
The Logitech K120 Keyboard is known for its cheap price and comfort. It also has slits at the bottom of the keyboard to allow liquids to flow out of the keyboard. Luckily, the keyboard is also very easy to disassemble and that’s exactly what this guide is for.
Video Overview
    1. Logitech K120 Keyboard Disassembly, Removing Screws: step 1, image 1 of 2 Logitech K120 Keyboard Disassembly, Removing Screws: step 1, image 2 of 2
      • Remove the Phillips #000 screw. Turn the screwdriver counter-clockwise.
      Ask FixBot
    2. Logitech K120 Keyboard Disassembly, Separating The Keyboard's Chassis: step 2, image 1 of 3 Logitech K120 Keyboard Disassembly, Separating The Keyboard's Chassis: step 2, image 2 of 3 Logitech K120 Keyboard Disassembly, Separating The Keyboard's Chassis: step 2, image 3 of 3
      • Use the spudger to separate the top of keyboard from the bottom of the keyboard.
      Ask FixBot
    3. Logitech K120 Keyboard Disassembly, Removing The Top Of The Keyboard: step 3, image 1 of 1
      • Remove the top of the keyboard and put it aside.
      Ask FixBot
    4. Logitech K120 Keyboard Disassembly, Removing The Bracket: step 4, image 1 of 3 Logitech K120 Keyboard Disassembly, Removing The Bracket: step 4, image 2 of 3 Logitech K120 Keyboard Disassembly, Removing The Bracket: step 4, image 3 of 3
      • Unscrew the highlighted screws using a Phillips #000 Screwdriver. Turn the screwdriver counter-clockwise.
      Ask FixBot
    5. Logitech K120 Keyboard Disassembly, Removing The Circuit Board: step 5, image 1 of 3 Logitech K120 Keyboard Disassembly, Removing The Circuit Board: step 5, image 2 of 3 Logitech K120 Keyboard Disassembly, Removing The Circuit Board: step 5, image 3 of 3
      • Use the spudger and carefully pry the connector out of its socket. (Highlighted in the pictures)
      Ask FixBot
    6. Logitech K120 Keyboard Disassembly, Removing The Cable: step 6, image 1 of 2 Logitech K120 Keyboard Disassembly, Removing The Cable: step 6, image 2 of 2
      • Carefully nudge the connector out of the hole in which the cable enters the keyboard's chassis.
      Ask FixBot
    7. Logitech K120 Keyboard Disassembly, Removing The Membrane: step 7, image 1 of 2 Logitech K120 Keyboard Disassembly, Removing The Membrane: step 7, image 2 of 2
      • Peel the membrane off carefully so that the membrane doesn't rip.
      Ask FixBot
    8. Logitech K120 Keyboard Disassembly, Remove The 2nd Membrane: step 8, image 1 of 3 Logitech K120 Keyboard Disassembly, Remove The 2nd Membrane: step 8, image 2 of 3 Logitech K120 Keyboard Disassembly, Remove The 2nd Membrane: step 8, image 3 of 3
      • Stick the sharp end of the spudger into the corner of the second membrane and bring the spudger partly underneath the membrane.
      • Lift the membrane off of the first standoff.
      • Peel the rest of the membrane off carefully so the membrane doesn't rip.
      Ask FixBot
Finish Line
4 other people completed this guide.
Author
with
Camuise
1,675 Reputation
7 Guides authored
4 Guide Comments
I followed your guide for disassembly and did the opposite for reassembly, now all three leds turn on when plugged in but none of the keys respond. Any idea what I should do?
Jacob Sileski - Reply Share
Make sure that the rubber membrane is making contact with the pads on the plastic sheets. If they are, make sure the connector is fully plugged in. If it is, make sure the keyboard is plugged into the right USB port.
Camuise - Reply Share
Haven't answered my real question does one repair or replace circuit membrane when liquid has shorted on line? Or throw out and buy a new keyboard?
KimKostyna - Reply Share
Your best bet is to try and clean up the membrane using isopropyl alcohol. There doesn't seem to be anywhere to buy a new circuit membrane, so if that doesn't work you'll most likely have to buy a new keyboard.
Past 24 Hours: 11
Past 7 Days: 60
Past 30 Days: 291
All Time: 14,701
