Logitech K Series Keyboard Feet Replacement
    1. Logitech K Series Keyboard Feet Replacement, Prepare your keyboard for disassembly: step 1, image 1 of 2 Logitech K Series Keyboard Feet Replacement, Prepare your keyboard for disassembly: step 1, image 2 of 2
      • Slide the power switch on the top right corner to the OFF position.
      • Flip your keyboard over and lay it down so the edge with the two tilt legs is closest to you.
      • If your work surface might scratch the keyboard, place a soft towel under it.
      Ask FixBot
    1. Logitech K Series Keyboard Feet Replacement, Remove the three feet: step 2, image 1 of 3 Logitech K Series Keyboard Feet Replacement, Remove the three feet: step 2, image 2 of 3 Logitech K Series Keyboard Feet Replacement, Remove the three feet: step 2, image 3 of 3
      • Light adhesive secures the three rubber feet along the edge of the keyboard. If you're having trouble removing them, use an iOpener or hair dryer to lightly heat them.
      • Insert the point of a spudger under an end of the foot.
      • Push the spudger underneath the foot and lift until you can grip it with your fingers.
      • Peel the foot up and remove it.
      Ask FixBot
    2. Logitech K Series Keyboard Feet Replacement: step 3, image 1 of 2 Logitech K Series Keyboard Feet Replacement: step 3, image 2 of 2
      • Repeat the previous step to remove the two remaining feet.
      Ask FixBot
    1. Logitech K Series Keyboard Feet Replacement, Flip up the tilt legs: step 4, image 1 of 3 Logitech K Series Keyboard Feet Replacement, Flip up the tilt legs: step 4, image 2 of 3 Logitech K Series Keyboard Feet Replacement, Flip up the tilt legs: step 4, image 3 of 3
      • Use your fingers to flip up both tilt legs.
      Ask FixBot
    2. Logitech K Series Keyboard Feet Replacement, Remove the feet: step 5, image 1 of 3 Logitech K Series Keyboard Feet Replacement, Remove the feet: step 5, image 2 of 3 Logitech K Series Keyboard Feet Replacement, Remove the feet: step 5, image 3 of 3
      • Light adhesive secures the rubber feet on the tilt legs. If you're having trouble removing them, use an iOpener or hair dryer to lightly heat them.
      • Use your finger to push the bottom of the foot up, separating its adhesive.
      • Peel up and remove the foot.
      Ask FixBot
    3. Logitech K Series Keyboard Feet Replacement: step 6, image 1 of 3 Logitech K Series Keyboard Feet Replacement: step 6, image 2 of 3 Logitech K Series Keyboard Feet Replacement: step 6, image 3 of 3
      • Repeat the previous step to remove the other tilt leg foot.
      Ask FixBot
Spencer Day
201,079 Reputation
1,243 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 61
All Time: 636
