Up to 20% off select tools
Logitech Harmony Ultimate Battery Replacement
Views: 57K
View statistics:
Past 24 Hours:
29
Past 7 Days:
200
Past 30 Days:
694
All Time:
56,803
Comments: 28
6 comments on steps, 22 guide comments.
Go to guide comments
Completed: 36
36 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If your battery keeps dying then refer to this short and easy guide on how to remove and replace your battery. The device components are delicate so be sure to take care when opening the device. Recommended for this guide are plastic opening tools and a phillips screwdriver. The most difficult part of this guide is locating all of the screws and physically opening the back panel of the remote.
    1. Logitech Harmony Ultimate Battery Replacement, Battery: step 1, image 1 of 1
      • Remove the single 6 mm Phillips #0 screw located beneath the sticker near the USB charging port.
      Ask FixBot
    2. Logitech Harmony Ultimate Battery Replacement: step 2, image 1 of 2 Logitech Harmony Ultimate Battery Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to release tabs that hold the front panel and back panel together. There are three tabs on each side of the device that need to separate for the device to open.
      • The use of a plastic opening tool is recommended to avoid damaging the remote. Use stronger tools as a last resort.
      • Be careful on the right side (looking at the back side) not to hit the screen ribbon cable. If that is hit and breaks, the touchscreen will not work properly. (example shown in the image)
      Ask FixBot
    3. Logitech Harmony Ultimate Battery Replacement: step 3, image 1 of 2 Logitech Harmony Ultimate Battery Replacement: step 3, image 2 of 2
      • Disconnect the wires running from the back cover to the motherboard.
      Ask FixBot
    4. Logitech Harmony Ultimate Battery Replacement: step 4, image 1 of 1
      • Remove the four 6mm Phillips #0 screws from the battery case.
      Ask FixBot
    5. Logitech Harmony Ultimate Battery Replacement: step 5, image 1 of 1
      • The battery is still connected to the device via wiring. To free the battery completely, remove the dark plastic piece from the slot with the plastic opening tool. Slowly rotate the dark plastic piece and the battery clockwise until then can be removed from underneath the small circuit board with the USB port.
      • Removing the dark plastic piece from the motherboard takes some patience, as the remote is designed so that the battery will not dislocate under extreme conditions. The small circuit board with the USB port remains connected to the motherboard by six 10 mm pins.
      Ask FixBot
    6. Logitech Harmony Ultimate Battery Replacement: step 6, image 1 of 1
      • Lift the battery and its case out of the remote.
      • The battery should still be connected to the case with adhesive.
      Ask FixBot
    7. Logitech Harmony Ultimate Battery Replacement: step 7, image 1 of 2 Logitech Harmony Ultimate Battery Replacement: step 7, image 2 of 2
      • Use the plastic opening tool to separate the battery from the case.
      Ask FixBot
36 other people completed this guide.
Author
with
Aaron Diaz
728 Reputation
3 Guides authored
USF Tampa, Team 8-1, Eyestone Fall 2015 Member of USF Tampa, Team 8-1, Eyestone Fall 2015
USFT-EYESTONE-F15S8G1
5 Members
60 Guides authored
22 Guide Comments
A bit dissapointed with Logitech’s “throw the remote away when the battery dies” instructions on their site. However, this guide was easy and means I have a functioning remote again (only 18 months old!). Many thanks for the guide.
Alec Dunn - Reply Share
Step 6 (disassembly and re-assembly) Only thing to point out is that the PCB on the bottom of the battery holder twists into the holder (small plastic holding feature). This is important to get proper alignment of the Micro-USB connector). When removing the battery holder make sure the PCB pops out of the snap that is on the opposite side from the screw that holds the Micro-USB connector. This avoids putting too much strain on the leads of that PCB.
Brian - Reply Share
Wish I read the comments before I did the work - came close to snapping the leads. To anyone trying this, the battery holder is not attached to that small pcb but rather there are small notches that hold the battery case in place. Knowing that will allow you to apply the right pressure in the right places to move it away from the PCB.
vinny - Reply Share
Rest of the instructions were fairly self explanatory, although I'm grateful for the confirmation to reduce risk
This point is an absolute saver though!
Fixing is Play - Reply Share
Battery model please
Mario Poirier - Reply Share
Past 24 Hours: 29
Past 7 Days: 200
Past 30 Days: 694
All Time: 56,803
