Up to 20% off select tools
Logitech Harmony Touch Power Adapter Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
109
All Time:
1,198
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
If the internal power adapter for your Logitech Harmony Touch Universal Remote, (Model Number 915-000279 or 915-000198) stops working, (won't charge, etc.), this guide will show you how to replace it.
The power adapter helps to narrow down the amount of voltage going into the product from its electrical source.
Before beginning, make sure to check the port for any debris. If any removable debris exists, use a small dust blower to remove it.
    1. Logitech Harmony Touch Power Adapter Replacement, Power Adapter: step 1, image 1 of 1
      • Open the latch that assesses the charging port.
      • Remove the black sticker and remove the screw with the indicated screwdriver.
      Ask FixBot
    2. Logitech Harmony Touch Power Adapter Replacement: step 2, image 1 of 2 Logitech Harmony Touch Power Adapter Replacement: step 2, image 2 of 2
      • Take the plastic opening tool and run it down the side of the remote to pop the case open.
      • While doing this step there are three wires that connect the two pieces, be sure not to rip them out when opening.
      • Detach the white clamp to partially disconnect the case from the motherboard.
      Ask FixBot
    3. Logitech Harmony Touch Power Adapter Replacement: step 3, image 1 of 1
      • Once your device is open, check to see if wires are intact.
      • If wires are not intact, solder your wires back in place to ensure contact with your charging port.
      Ask FixBot
Author
with
Jennifer Jimenez
228 Reputation
1 Guide authored
USF Tampa, Team S4-G2, Eyestone Fall 2017 Member of USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 109
All Time: 1,198
