Logitech Harmony Touch Motherboard Replacement
    1. Logitech Harmony Touch Motherboard Replacement, Motherboard: step 1, image 1 of 3 Logitech Harmony Touch Motherboard Replacement, Motherboard: step 1, image 2 of 3 Logitech Harmony Touch Motherboard Replacement, Motherboard: step 1, image 3 of 3
      • Open the latch that covers the charging port.
      • Remove the black sticker, then remove the screw with the indicated screwdriver.
      • Take the plastic opening tool, and run it down the side of the remote to pop the case open.
      • While doing this step, there are three wires that connect the two pieces. Be sure not to rip the wires out.
      • Detach the white clamp in order to partially disconnect the case from the motherboard.
      Ask FixBot
    2. Logitech Harmony Touch Motherboard Replacement: step 2, image 1 of 3 Logitech Harmony Touch Motherboard Replacement: step 2, image 2 of 3 Logitech Harmony Touch Motherboard Replacement: step 2, image 3 of 3
      • Peel back the thin yellow plastic film and detach the clip found underneath.
      • Remove the screws that connect the motherboard to the case with the suggested screwdriver.
      Ask FixBot
      • Next, carefully remove the motherboard from the top piece of the case.
      • The motherboard is connected to the bottom part of the case.
      • You should now be able to access all of the buttons and remove them from the case.
      Ask FixBot
Lennox Saliva-Rojas
290 Reputation
2 Guides authored
USF Tampa, Team S4-G2, Eyestone Fall 2017 Member of USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 1,084
