Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement
  1. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement, Back Panel: step 1, image 1 of 2 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement, Back Panel: step 1, image 2 of 2
    • Turn keyboard over to the backside.
    Ask FixBot
  2. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 2, image 1 of 3 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 2, image 2 of 3 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 2, image 3 of 3
    • Press and slide up on the upper battery latch, using both thumbs.
    Ask FixBot
  3. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 3, image 1 of 1
    • Remove the two AA batteries and set them aside.
    Ask FixBot
  4. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 4, image 1 of 2 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 4, image 2 of 2
    • Unscrew all five 4.0 mm screws, using Phillips #1 screwdriver.
    Ask FixBot
  5. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 5, image 1 of 2 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 5, image 2 of 2
    • Peel off the center sticker to reveal two hidden 4.0 mm screws.
    • Unscrew these two screws with a Phillips #1 screwdriver.
    Ask FixBot
  6. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 6, image 1 of 3 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 6, image 2 of 3 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 6, image 3 of 3
    • Lift both top left and top right rubber stickers halfway, using the sharp end of the plastic spudger.
    • Unscrew a total of two 4.0 mm screws, under the rubber stickers, using a Phillips #1 screwdriver.
    Ask FixBot
  7. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 7, image 1 of 2 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 7, image 2 of 2
    • Unscrew the top center 4.0 mm screw, in the battery compartment, using the Phillips #1 screwdriver.
    • Now, you should have a total of ten 4.0 mm screws set aside.
    Ask FixBot
  8. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 8, image 1 of 3 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 8, image 2 of 3 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 8, image 3 of 3
    • Wedge the flat end of the spudger between the back panel and front panel.
    • Slide the flat end of the spudger from right to left to pry the two panels apart.
    Ask FixBot
  9. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 9, image 1 of 3 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 9, image 2 of 3 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 9, image 3 of 3
    • Separate the back panel from the front panel completely, using both hands.
    • A white ribbon flex cable will remain connected to both panels.
    • Pull the panels apart slowly and gently, or the white ribbon flex cable may be unsafely removed.
    Ask FixBot
  10. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement, Keyboard Printed Circuit Board (PCB): step 10, image 1 of 3 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement, Keyboard Printed Circuit Board (PCB): step 10, image 2 of 3 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement, Keyboard Printed Circuit Board (PCB): step 10, image 3 of 3
    • Grip the lower end of the ribbon flex cable (white band) using your thumb and index finger.
    • Then slide the strip out toward yourself in a scooping motion.
    • Now, you should have two completely separated panel pieces.
    Ask FixBot
  11. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 11, image 1 of 3 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 11, image 2 of 3 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 11, image 3 of 3
    • Lift and remove the white rubber sheet that lays over the keyboard pet flexible PCB.
    Ask FixBot
  12. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 12, image 1 of 3 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 12, image 2 of 3 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 12, image 3 of 3
    • Unscrew the two 4.0 mm screws on either side of the green card using a Phillips #1 screwdriver.
    Ask FixBot
  13. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 13, image 1 of 1
    • Lift the green card up using the flat end of the plastic spudger.
    Ask FixBot
  14. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 14, image 1 of 1
    • Grip and lift the keyboard PCB up and out.
    • The battery wires will remain connected.
    Ask FixBot
  15. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 15, image 1 of 1
    • Grip and lift the battery wire bar out of the battery compartment, using your thumb and index finger.
    Ask FixBot
  16. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 16, image 1 of 2 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 16, image 2 of 2
    Tool used on this step:
    Buy
    • Pinch your precision tweezers and wedge the battery clamp up.
    • Lift the entire keyboard PCB out of the panel.
    • The keyboard PCB will remain connected to the green card.
    Ask FixBot
  17. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 17, image 1 of 3 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 17, image 2 of 3 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 17, image 3 of 3
    • Slide your index finger into the slot under the right blue tab.
    • Pinch and pull the right blue tab away from the green card.
    Ask FixBot
  18. Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 18, image 1 of 3 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 18, image 2 of 3 Logitech Harmony Smart Keyboard Key Printed Circuit Board (PCB) Replacement: step 18, image 3 of 3
    • Pinch and pull the left blue tab away from the green card.
    Ask FixBot
Hayley Nichols
525 Reputation
4 Guides authored
CSU Fullerton, Team S1-G2, Bruce Fall 2017 Member of CSU Fullerton, Team S1-G2, Bruce Fall 2017
CSUF-BRUCE-F17S1G2
3 Members
10 Guides authored
2 Guide Comments
This is really very informative to read and helpful while replacement or cleaning theprinted circuit board . I really want my friend companies engineer to read this type of information and work on it in practical. i wanna tag that company here as well @XG-technologies (https://xg-pcb.com/). Moreover keep sharing these type of informative blogs. really liked it.
mark.tony40 - Reply Share
dnde cmprar el recambi, cm se ve n funcina la 0
Manuel Sánchez Varilla - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 53
All Time: 4,843
