Up to 20% off select tools
Logitech Harmony Smart Keyboard Back Panel
Views: 1.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
31
Past 30 Days:
98
All Time:
1,855
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
  • Spudger
    4.9
  • Phillips #1 Screwdriver
    5
Introduction
Go to step 1 ↓
This is a prerequisite guide that will instruct you on how to properly open your keyboard. This will be helpful for replacing internal components without damaging your device.
    1. Logitech Harmony Smart Keyboard Back Panel, Back Panel: step 1, image 1 of 2 Logitech Harmony Smart Keyboard Back Panel, Back Panel: step 1, image 2 of 2
      • Turn keyboard over to the backside.
      Ask FixBot
    2. Logitech Harmony Smart Keyboard Back Panel: step 2, image 1 of 3 Logitech Harmony Smart Keyboard Back Panel: step 2, image 2 of 3 Logitech Harmony Smart Keyboard Back Panel: step 2, image 3 of 3
      • Press and slide up on the upper battery latch, using both thumbs.
      Ask FixBot
    3. Logitech Harmony Smart Keyboard Back Panel: step 3, image 1 of 1
      • Remove the two AA batteries and set them aside.
      Ask FixBot
    4. Logitech Harmony Smart Keyboard Back Panel: step 4, image 1 of 2 Logitech Harmony Smart Keyboard Back Panel: step 4, image 2 of 2
      • Unscrew all five 4.0 mm screws, using Phillips #1 screwdriver.
      Ask FixBot
    5. Logitech Harmony Smart Keyboard Back Panel: step 5, image 1 of 2 Logitech Harmony Smart Keyboard Back Panel: step 5, image 2 of 2
      • Peel off the center sticker to reveal two hidden 4.0 mm screws.
      • Unscrew these two screws with a Phillips #1 screwdriver.
      Ask FixBot
    6. Logitech Harmony Smart Keyboard Back Panel: step 6, image 1 of 3 Logitech Harmony Smart Keyboard Back Panel: step 6, image 2 of 3 Logitech Harmony Smart Keyboard Back Panel: step 6, image 3 of 3
      • Lift both top left and top right rubber stickers halfway, using the sharp end of the plastic spudger.
      • Unscrew a total of two 4.0 mm screws, under the rubber stickers, using a Phillips #1 screwdriver.
      Ask FixBot
    7. Logitech Harmony Smart Keyboard Back Panel: step 7, image 1 of 2 Logitech Harmony Smart Keyboard Back Panel: step 7, image 2 of 2
      • Unscrew the top center 4.0 mm screw, in the battery compartment, using the Phillips #1 screwdriver.
      • Now, you should have a total of ten 4.0 mm screws set aside.
      Ask FixBot
    8. Logitech Harmony Smart Keyboard Back Panel: step 8, image 1 of 3 Logitech Harmony Smart Keyboard Back Panel: step 8, image 2 of 3 Logitech Harmony Smart Keyboard Back Panel: step 8, image 3 of 3
      • Wedge the flat end of the spudger between the back panel and front panel.
      • Slide the flat end of the spudger from right to left to pry the two panels apart.
      Ask FixBot
    9. Logitech Harmony Smart Keyboard Back Panel: step 9, image 1 of 3 Logitech Harmony Smart Keyboard Back Panel: step 9, image 2 of 3 Logitech Harmony Smart Keyboard Back Panel: step 9, image 3 of 3
      • Separate the back panel from the front panel completely, using both hands.
      • A white ribbon flex cable will remain connected to both panels.
      • Pull the panels apart slowly and gently, or the white ribbon flex cable may be unsafely removed.
      Ask FixBot
2 other people completed this guide.
Author
with
Hayley Nichols
525 Reputation
4 Guides authored
CSU Fullerton, Team S1-G2, Bruce Fall 2017 Member of CSU Fullerton, Team S1-G2, Bruce Fall 2017
CSUF-BRUCE-F17S1G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 98
All Time: 1,855
