Up to 20% off select tools
Logitech Harmony Smart Control Reset Button Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
90
All Time:
1,543
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Difficult
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
Introduction
Go to step 1 ↓
This guide requires soldering, for soldering guide click below.
Soldering Guide
    1. Logitech Harmony Smart Control Reset Button Replacement, Reset Button: step 1, image 1 of 2 Logitech Harmony Smart Control Reset Button Replacement, Reset Button: step 1, image 2 of 2
      • Using a plastic opening tool, lift up the rubber pad.
      • From the bottom of the device, with your fingers, pull back the rubber pad. This will expose the screw holes.
      • On the bottom of the hub, repeat the step above for the second rubber pad.
      Ask FixBot
    2. Logitech Harmony Smart Control Reset Button Replacement: step 2, image 1 of 2 Logitech Harmony Smart Control Reset Button Replacement: step 2, image 2 of 2
      • With the PH00 bit, remove the four 6mm Phillips screws.
      Ask FixBot
    3. Logitech Harmony Smart Control Reset Button Replacement: step 3, image 1 of 2 Logitech Harmony Smart Control Reset Button Replacement: step 3, image 2 of 2
      • With the plastic opening tool, separate the pieces of plastic from each other
      Ask FixBot
    4. Logitech Harmony Smart Control Reset Button Replacement: step 4, image 1 of 2 Logitech Harmony Smart Control Reset Button Replacement: step 4, image 2 of 2
      • With the PH00 bit, remove the three 4mm Phillips screws.
      Ask FixBot
    5. Logitech Harmony Smart Control Reset Button Replacement: step 5, image 1 of 3 Logitech Harmony Smart Control Reset Button Replacement: step 5, image 2 of 3 Logitech Harmony Smart Control Reset Button Replacement: step 5, image 3 of 3
      • From the yellow corner, pry the circuit board from the housing..
      Ask FixBot
    6. Logitech Harmony Smart Control Reset Button Replacement: step 6, image 1 of 3 Logitech Harmony Smart Control Reset Button Replacement: step 6, image 2 of 3 Logitech Harmony Smart Control Reset Button Replacement: step 6, image 3 of 3
      • Locate the defective reset button.
      • Turn the board around to expose the reset solder.
      • Using soldering iron, remove solder and reset button. Replace reset button and solder.
      Ask FixBot
Author
with
Zachary Robinson
126 Reputation
1 Guide authored
IUPUI, Team 3-2, Harley Fall 2015 Member of IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 90
All Time: 1,543
